Offline petestra
#1 Posted : 16 July 2015 14:10:44(UTC)
Hi, I have watched several prototype railway Lok Videos and I am a bit confused about when these particular sounds occur on Loks?
Steam; 1. When is air pump used, for instance at station when standing or....?
2. Air Release , I believe each time after Lok stops?
3. Injector? While standing, riding...?
Diesels; 1. Blowers?
Electrics; 1. Blowers?
2. Injector?
3. Main relay? (as on SBB Re6/6)
4. Compressor?
Peter Confused
Offline Tom Jessop
#2 Posted : 16 July 2015 22:53:06(UTC)
Tom Jessop
1 & 4 are the same , Compressor & air pump start automatically when main reservoir air pressure is below a pre set level .
2 Air /brake release occurs after brakes have been operated or do you mean when max air pressure has been passed in the main reservoir .
3 Injector is manually operated when water is required in boiler , can be used anytime .
1a Blowers are used for traction motors in either Eloks or diesels to pressurise to stop dust entry & cooling effect .
2 No injectors on Eloks . On diesels ,on motor for fuel injection .
3 Main Relay is for connection of overhead to main switching on engine .
All of the above is based on Australian rail operations but the same would be relevant to any other railway .
Cheers Tom in Oz
thanks 6 users liked this useful post by Tom Jessop
Offline petestra
#3 Posted : 17 July 2015 01:17:16(UTC)
Cheers Tom in Oz
Terrific! Tom. Thanks so much for that info. Peter ThumpUp ThumpUp ThumpUp Smile
#4 Posted : 17 July 2015 07:50:16(UTC)
Not quite.
There are differences between diesel-electric and diesel-hydraulic locomotives. The later do not have electric driving motors (no individual blowers), but will have gears where hydraulic liquid will be injected before loco moves.
There also are diesel-mechanic vehicles.
This page was generated in 0.295 seconds.
