Offline Moritz-BR365
#1 Posted : 09 July 2015 08:26:52(UTC)
Moritz-BR365
I'm plaaning to convert my V80 model into a sound model, using the D&H SD21A-4 with the great new V100 sound projekt.
However, there is not much space and yes, there will be the new 36082 with full features incl. sound released this year.
But, I want to have the better D&H decoder and therefore, here my first impressions, how the decoder could be placed into the loco:
Not much space, it will become a bit tricky.
To be continued...
Edited by user 10 August 2015 10:09:32(UTC)  | Reason: Not specified
thanks 4 users liked this useful post by Moritz-BR365
Offline mmervine
#2 Posted : 09 July 2015 21:57:07(UTC)
mmervine
I would suggest using taking a look at this adapter plate:
http://luessi.ch/shop/ca...h=2&products_id=2362
I did a similar conversion a few years ago:
http://www.ete-ene.org/v80ConversionArticle.htm
At that time, I used a Trix board with an 8 pin socket.
thanks 3 users liked this useful post by mmervine
#3 Posted : 10 July 2015 07:23:57(UTC)
Moritz-BR365
Thanks a lot for these usefull links!
#4 Posted : 10 August 2015 09:20:46(UTC)
Moritz-BR365
In meantime, I decided to use an PluX16 decoder, because it is much smaller. I choosed the new Doehler&Haass SD16A-4 PluX16-Sounddecoder. The PluXinterface board is from Uhlenbrock, it is a PluX22 71680:
Additionally, I took a stripboard to connect the Uhlenbrock interface board and to hold the motor in position:
The speaker is an 11x15 Zimo speaker, also available from different suppliers. I mounted a small sheet of aluminium above the cardan shaft and glued the speaker with the small sound box on it.
And this is how the V80 with Doehler&Haass SD16A-4 PluX16 Sounddecoder and DB V100 Sound project sounds:
Video:
thanks 2 users liked this useful post by Moritz-BR365
This page was generated in 0.344 seconds.
