Offline danmarklinman
#1 Posted : 25 May 2015 20:16:32(UTC)
danmarklinman
Hi can anyone tell me if Trix did a DB red or Ralion, x4 pantograph 185 please. And if possible, what cat number is it please.
Wiking model car Fan
Instagram: marklin1978
Wiking fan
#2 Posted : 25 May 2015 20:30:47(UTC)
22761 from 2006 (Hobby loco with metal body, BR 185.0).
#3 Posted : 25 May 2015 21:59:04(UTC)
Euromodeltrains has the Roco 72522 Railion on special for $132.99
#4 Posted : 26 May 2015 11:02:24(UTC)
danmarklinman
Hi thanks for your input. What wanted the Trix one for is, to swop loco bodies over with my Marklin 3 rail traxx models. Unfortunately the cost of convertion to two rail is to high as I would have to put two rail wheels on all my stock, and I would have to clean the trackBigGrin
Apart from that I will just have to weight for a Marklin TGV DuplexLOL
Wiking fan
#5 Posted : 26 May 2015 16:36:39(UTC)
Märklin uses the same wheelsets for the two-rail and three-rail Hobby TRAXX locos and conversion is fairly simple in either way - at least if you have a multi-protocol controller.
Offline sjlauritsen
#6 Posted : 26 May 2015 16:53:00(UTC)
sjlauritsen
With regards to the Märklin Hobby locos: They all have DC wheel sets. So conversion is really simple. Simply remove the pick up shoe and move one power pick-up wire on the main board.
A wire bridges the gab between the two power pickups on the boggies, remove that wire and your model is a DC model.
I did that with a Märklin BR 146.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
#7 Posted : 26 May 2015 17:53:44(UTC)
If you want the shell for 3 rail AC, why don't you just search for 36856 (185 099) or 36893 (Railion Schweiz)? They can be had for the same price as the Trix model you were looking for.
#8 Posted : 26 May 2015 22:20:21(UTC)
danmarklinman
Thanks for the info, its good to know for possible future stuff. Cheers Dan
Wiking fan
#9 Posted : 28 May 2015 10:37:34(UTC)
danmarklinman
Hi, I don't suppose you could put a picture up, of what you have done to the circuit board. Cheers Dan.
Wiking fan
This page was generated in 0.340 seconds.
