Offline Teme
#1 Posted : 15 May 2015 14:46:04(UTC)
Teme
First message here hope I ask correct forum part.
I bought 3 2270 turnouts from amazon.com with a great price a time ago . I did not use them for a while, last week I made couple of changes on my layout and decided to use them. But realised that my track was short circuited after connect 2270. I remove everthing is fine, than measured resistance between tracks, a shockgin 2 ohm in every position. 3 of them are same. Is anyone experienced like this or any trick to fix them, I am out of return window unfortunatelly...
Thanks in advance...
Offline waorb
#2 Posted : 15 May 2015 15:38:04(UTC)
waorb
Brazil
Hello Teme.
Welcome!
Are you connecting those turnouts on an AC (3-rails) or DC (2-rails) layout?
Walter
Offline Teme
#3 Posted : 15 May 2015 15:51:06(UTC)
Teme
Hi Walter,
my layout is DC
Offline waorb
#4 Posted : 15 May 2015 16:48:55(UTC)
waorb
Brazil
Hello Teme.
Sorry to say, but you have a wrong piece of track for your layout. Short circuits are supposed to happen in your case.
Märklin 2270 is to be used in an AC layout (3-rails, ground on outside rails and positive on center rail).
Since you have a DC layout (2-rails, ground on one rail and positive on the other), you cannot use then on it.
Walter
This page was generated in 0.318 seconds.
