Offline Farnorth
#1 Posted : 12 May 2015 05:24:41(UTC)
Farnorth
Hi All,
I have an existing layout with 74490 turnout mechanisms. Two are faulty but the 74490 does not seem to be available as a new part.
Is the 74491 a replacement for the 74490?
Thanks in anticipation.
Edited by user 13 May 2015 06:01:38(UTC)  | Reason: Not specified
Offline witzlerh
#2 Posted : 12 May 2015 06:38:58(UTC)
witzlerh
Yes the 74491 is the replacement.
However, if it is an issue that they only switch one way, you may be able to salvage the motors.
Ther are several posts describing the issue and the workaround well. Do a search or maybe some members know how to post the links.
The most common problem is that the end travel relay switches are easily fried. You can jumper them, particularly if you operate the switches with a digital system. If you use an analogue push buttons, you may be at greater risk to fry the motor itself if you lean on the buttons too long.
I have jumpered several switch motor end stop relays and enjoyed many years of operation since then.
Harald
CS2 DB & Canadian Era 3-6
Offline 3rail4life
#3 Posted : 12 May 2015 20:43:48(UTC)
3rail4life
The digital only repair:
Thank you Oscar Tamayo!
thanks 2 users liked this useful post by 3rail4life
This page was generated in 0.334 seconds.
