Offline vnangli
#1 Posted : 09 May 2015 23:55:29(UTC)
vnangli
I am planning to buy Marklin 60113 Digital controller box. I know Marklin 74041 FCC interference pack is required in the US.
My 2 questions??
1) Does 60113 come with a connector ready for 74041??
2) Is it absolutely necessary to use 74041 in the USA, if in case the 60113 I buy doesn't come with connector ready for 74041???
Eagerly waiting for your suggestions
VJ
Offline 3rail4life
#2 Posted : 10 May 2015 00:17:49(UTC)
3rail4life
Hi VJ,
None of my 60113's ever came with the 74041 set, and I have never used one but from what I have read and heard, they and other similar parts may cause problems with mFX loco registration on the MS2. So I would recommend not using it.
from the AJCKids site: "The FCC interference suppression set is required only in the USA! Which means that either interference must only be a problem in the USA, or we have extra rules and restrictions in the USA, designed to keep certain government agencies in business."
Gordon
Offline rorosha
#3 Posted : 10 May 2015 00:40:27(UTC)
rorosha
My 2 questions??
VJ
I recently purchased a starter set which included the MS2 (60653) and 60113 Connector box. It came with the 74041 Interference filter already wired in. A quick check of images on the internet shows that the 74041 Interference Filter comes with the connector (the green thing opposite the wires). The connector probably does not come with the MS2 (60653), except maybe the very newest builds. But I doubt it, since the 74041 is only required in the US.
About the 74041 being absolutely necessary. Technically yes. In order for the 60113 to be used in the US, it must be used with all included devices. Märklin had to have the unit certified, and in order to get the unit certified, they had to install the 74041 inline with the 60113. And technically, since the 60113 had to for some reason be re-certified, YOU are responsible to meet the new certification requirements, if you intend to use the unit (60113).
The FCC does have some overly strict rules about interference. They can make things difficult, excessively so, for manufacturers. But manufacturers and consumers have little choice.
In reality, as far as using it. If your MS2 (60113) did not come with it, don't use it. If your MS2 (60113) did come with it, you should use it. Personally, the first thing that I did (actually not the first thing, the first thing was to see if it fit under C track, which it does not) was to remove it and install the regular C track connectors on the wires from the 60113.
I did keep it, so that if by some odd chance there was an interference complaint linked to this MS2, I can reinstall it.
So, in the end, I would say, "use 'em if ya got 'em". If not, the "I didn't know I needed it" defense would be best. It's a fifteen dollars I wouldn't spend unless forced to at gunpoint.
Rodger
thanks 1 user liked this useful post by rorosha
#4 Posted : 10 May 2015 08:30:21(UTC)
Current Märklin locos come without FCC approval, so with or without 74041 you will sooner or later violate the FCC regulations.
And yes: mfx may fail with the 74041 installed.
It will make a difference whether the next neighbour is 10 metres or 10 miles away.
This page was generated in 0.494 seconds.
