Offline Varun R
#1 Posted : 09 May 2015 17:55:53(UTC)
Varun R
Hello all, i have a problem with my locomotives. Whenever the locomotives run on the track, they keep on stopping abruptly very often. One locomotive especially, stops very often. I dont know if it is lose connection, low battery or what. Looking for help. Thanks
#2 Posted : 09 May 2015 18:25:36(UTC)
If this post was in the H0 section, we would at least know the scale. So we know nothing.
Some information about the track system and the locos would help.
Offline Varun R
#3 Posted : 09 May 2015 19:20:39(UTC)
Varun R
Yes, sorry. its in the HO section.
#4 Posted : 09 May 2015 20:17:21(UTC)
You mentioned batteries. Is this a problem with the "My world" battery sets or battery operated controllers of digital sets?
If it's the digital locomotives running with battery operated handsets, then the cause is more likely to be dirty tracks. Give the rails a good clean with a solvent such as alcohol or white spirit.
Offline Varun R
#5 Posted : 10 May 2015 10:30:40(UTC)
Varun R
I think the problem will be dust. Because the tracks have got really dusty. Thanks for your reply. Will tell if i have any more problems. Thank you.
#6 Posted : 10 May 2015 11:37:37(UTC)
Contact problems after several days of inactivity are often caused by rust on the centre rail.
Run the loco a few rounds at full speed and contact should improve from round to round if rust is the problem.
It cannot harm to clean the outer rails (using non-abrasive methods).
This page was generated in 0.612 seconds.
