Offline Tom Jessop
#1 Posted : 04 May 2015 07:28:46(UTC)
Tom Jessop
I have some M track points that have been previously converted to run the point Lantern on a separate feed but uses the road bed return . The solenoid is using the normal set up . Will the return feed from the light interfere with the digital feed from a CS1 reload as the M track running rails are the common wire ? I would be using a variable rheostat to control the brightness of the light after going thru a AC/DC power supply .
Cheers Tom in OzConfused
#2 Posted : 04 May 2015 07:40:01(UTC)
Hi, Tom,
A common ground between CS1 and external power sources is no problem. Do not connect anything else to the power supply of the CS1.
Offline Tom Jessop
#3 Posted : 04 May 2015 07:50:58(UTC)
Tom Jessop
From 1 Tom to another Tom ,Thanks very much .
This page was generated in 0.221 seconds.
