Offline drstapes
#1 Posted : 23 April 2015 18:07:51(UTC)
drstapes
Hi All,
I just bought this 2-10-2 steam tank engine off ebay. As not unexpected it has problems with reversing. IE when you try it buzzes and nothing happens. Presumably a reverser spring problem . Its complicated by the fact it is equipped with Telex. I thought I would open it before sending the engine back but there is no obvious way to take the body shell off the chassis. May be screws under couplers but I do not want to fiddle with it without knowing the correct way of removing the shell. Anybody with this loco who can give me some advice?
thanks
Geoff
Geoff (UK)
#2 Posted : 23 April 2015 19:31:27(UTC)
Originally Posted by: drstapes Go to Quoted Post
Hi All,
thanks
Geoff
Hi Geoff,
You remove two screws from underneath, close to the cylinders. Then you pull the boiler up and backwards. Look in the manual:
http://medienpdb.maerkli.../1/pdf/37097_betrieb.pdf
RayF attached the following image(s):
Offline MS 800
#3 Posted : 23 April 2015 19:38:34(UTC)
MS 800
Hi, Geoff,
it works as RayF describes it - not really difficult - nor really obvious. I got the 3309 as well - including the complete manual. If you'd like to receive a .PDF copy of it, just PM me your E-Mail-Adress and I'll send it.
Best
MS 800
When we were kids we enjoyed our tinplate trains rattling over tinplate tracks - nowadays they're in need of sound decoders.
Offline drstapes
#4 Posted : 23 April 2015 22:23:59(UTC)
drstapes
Ray and MS800, Thanks very much for your replies all a great help
Geoff
Geoff (UK)
thanks 1 user liked this useful post by drstapes
Offline Joseph Meiring
#5 Posted : 24 April 2015 13:08:02(UTC)
Joseph Meiring
One of my all time favorite locos, such a nice looking loco! - mine is from the mid 80's......have digitized it, and it really runs beautifully: great for shunting with the Telex; thinking of putting in a sound decoder now.....
Joe
Offline drstapes
#6 Posted : 24 April 2015 16:48:47(UTC)
drstapes
Hi All,
thanks
Geoff
Hi Geoff,
Well I managed to dismantle the loco, to my dismay the reversing unit is damaged and the lever that turns the rotating cog is flapping in the breeze. It looks like the plastic transparent housing is broken. Therefore back to the seller. Incidentally its really fiddly to put the body back on the little screws are very inaccessible.
Geoff
Geoff (UK)
Offline waorb
#7 Posted : 24 April 2015 18:20:39(UTC)
waorb
Brazil
Hello Geoff.
It's not worth just changing the reverse unit? There is a lot of them available...
(I personally have some... from digitalized loks)
Walter
edit: maybe not worth... Blushing
http://www.ebay.de/itm/Marklin-229700-258910-Fahrtrichtungsschalter-Telex-3309-3709-Dampflok-BR85-007-/361278609885?pt=LH_DefaultDomain_77&hash=item541de219dd
Offline drstapes
#8 Posted : 24 April 2015 22:22:45(UTC)
drstapes
Hello Geoff.
Walter
Well I have retuned the loco to the original seller. Keep my fingers crossed
Geoff
Geoff (UK)
Offline drstapes
#9 Posted : 07 May 2015 17:06:51(UTC)
drstapes
All's well that's ends well. I got a refund and brought a very nice SEH 800, (3013) unboxed, but in excellent order. .so well pleased in the end
Geoff (UK)
This page was generated in 0.666 seconds.
