#1 Posted : 23 March 2015 20:01:36(UTC)
SUMMER NEW ITEMS BROCHURE NOW
DOWNLOAD IN PDF ENGLISH 5MB
>>>>>>>LINK<<<<<<
Edited by user 16 April 2015 10:59:47(UTC)  | Reason: Not specified
thanks 21 users liked this useful post by steventrain
#2 Posted : 04 April 2015 21:00:49(UTC)
List update.
Offline rbonet
#3 Posted : 06 April 2015 17:56:11(UTC)
rbonet
The Maerklin.com page describing the 37835 Steam class BR50 Cabin Tender mentions that "A tank car set to go with this steam freight locomotive can be found under item number 46536". This reference is not yet in the database.
Collecting Era I, II & III, mainly German, French & Spanish RR, some USA
thanks 1 user liked this useful post by rbonet
#4 Posted : 06 April 2015 18:01:36(UTC)
46536 will show up if Summer new items 2015 on Marklin database due late mid April.
Offline jonas_sthlm
#5 Posted : 06 April 2015 19:02:01(UTC)
jonas_sthlm
It must be something more for det swedish market when all tree item arrive Q4 Cool
I order 37835 and 46536 through trainshop.se
#6 Posted : 09 April 2015 22:13:55(UTC)
New 43805 add to list!
Also Image of 29012 and 29290 Both due in stock next month
>LINK TO 29290<
>LINK TO 29012<
thanks 8 users liked this useful post by steventrain
#7 Posted : 14 April 2015 17:19:45(UTC)
Update See first post with red letter.
#8 Posted : 14 April 2015 20:14:37(UTC)
Oh no, a DRG S2/6 already (with car set)...
My bank account will cry big time.... Mellow
#9 Posted : 14 April 2015 21:30:18(UTC)
37016 will be in normal grey loco box, No wooden box.
37016 detail -
Prototype: Bavarian class S 2/6 steam express locomotive in a black/red basic paint scheme as the German State Railroad Company (DRG) class 15. Locomotive road number 15 001. The locomotive looks as it did around 1925.
Model: The locomotive has an mfx digital decoder and extensive sound functions. It also has controlled high-efficiency propulsion. 2 axles powered. Traction tires. The 72270 smoke unit can be installed in the locomotive. The dual headlights change over with the direction of travel. They and the smoke unit that can be installed in the locomotive will work in conventional operation and can be controlled digitally. The headlight for oncoming trains and the cab lighting can be controlled in digital operation. Maintenance-free warm white LEDs are used for the lighting. The locomotive has detailed running gear with a partially open bar frame. The locomotive is modeled to show streamlined sheathing of the smoke box, smoke stack, dome, and cylinder group as well as the streamlined cab. There is a close coupling between the locomotive and tender. A close coupler with a guide mechanism and an NEM pocket is mounted on the rear of the tender. The minimum radius for operation is 360 mm / 14-3/16". Protective sleeves for the piston rods are included separately. Length over the buffers 25.1 cm / 9-7/8".
Highlights:
•Completely new tooling for the class S 2/6.
•Very finely detailed construction.
•Prototypical detail changes.
•Locomotive and tender constructed mostly of metal.
•mfx decoder with extensive light and sound functions.
One-time series.
#10 Posted : 14 April 2015 21:32:34(UTC)
39007 BR01 came with wooden box - Very limited!
Prototype: German Federal Railroad (DB) class 01 express steam locomotive with a type 2´2´T34 coal tender. Large Wagner smoke deflectors, silver boiler bands, buffer plate warning stripes. Road number 01 126. The locomotive looks as it did around 1950.
Model: The locomotive has an mfx+ digital decoder and extensive sound functions. It also has controlled high-efficiency propulsion with a flywheel, mounted in the boiler. 3 axles powered. Traction tires. The locomotive and tender are constructed mostly of metal. The locomotive has a factory-installed 7226 smoke unit. The dual headlights change over with the direction of travel. They and the smoke unit will work in conventional operation and can be controlled digitally. The locomotive has firebox flickering. Maintenance-free warm white LEDs are used for the lighting. There is a permanent close coupling with a guide mechanism between the locomotive and tender that can be adjusted for track curves. The rear of the tender has a close coupler with an NEM pocket and a guide mechanism. Protective piston sleeves, brake hoses, and figures of a locomotive engineer and a fireman are included. The minimum radius for operation is 360 mm / 14-3/16". The model comes in an attractive wooden case with a certificate of authenticity. Length over the buffers 27.5 cm / 10-13/16".
Highlights:
•mfx+ digital decoder included.
•Firebox flickering.
•Certificate of authenticity.
One-time limited series.
Offline vilithejou
#11 Posted : 14 April 2015 21:40:12(UTC)
vilithejou
Highlights:
Photos on marklin database if you know how...
http://medienpdb.maerkli...g/grossansicht/39007.jpg
http://medienpdb.maerkli...g/grossansicht/37016.jpg
Joan Vilarrúbia
vilithejou@yahoo.es
Fan of Märklín, Kroko lover
thanks 2 users liked this useful post by vilithejou
#12 Posted : 14 April 2015 21:41:51(UTC)
Marklin is to set up 'Summer news items' on database today but only 37835 on it.
http://www.maerklin.com/...talogue=1540&submit=
Full of Summer items will be showing tomorrow!
Offline pn
#13 Posted : 14 April 2015 22:01:01(UTC)
pn
thanks 9 users liked this useful post by pn
Offline mrmarklin
#14 Posted : 15 April 2015 03:12:15(UTC)
mrmarklin
I could be facing bankruptcy.Bored Lots of Era II items, and good ones too.Love
thanks 4 users liked this useful post by mrmarklin
Offline sjlauritsen
#15 Posted : 15 April 2015 07:42:19(UTC)
sjlauritsen
That EP 3/6 looks so great with the little coach set. Smile I can almost hear it calling my name...
Søren from Denmark
thanks 2 users liked this useful post by sjlauritsen
#16 Posted : 15 April 2015 08:47:08(UTC)
You have been a member since:: 08/12/2004(UTC)
I am very Angry .E8A and now E8B for small scale and nothing for HO scale.LOL BigGrin
#17 Posted : 15 April 2015 08:50:26(UTC)
The 46536 tank car set is very nice,a very nice addition for my era III collection.ThumpUp
Offline Andrey
#18 Posted : 15 April 2015 08:53:27(UTC)
Andrey
Russian Federation
Very good steam oriented items! ThumpUp Almost everything that predicted Stephen Wink
I'll take 37950 BR 03. Eventually BR 03 with Wagner deflectors appears with sound... Smile
Still no info on this year's Borsig Edition or I missed something?
thanks 2 users liked this useful post by Andrey
#19 Posted : 15 April 2015 09:38:02(UTC)
I contact Marklin two months ago but not heard yet. Maybe wait for Fall 2015.
#20 Posted : 15 April 2015 09:44:34(UTC)
I'm sure you misheard, Søren. It's definitely calling MY name! BigGrin
#21 Posted : 15 April 2015 11:02:32(UTC)
Originally Posted by: pn Go to Quoted Post
Hmm, 8 pages for the Trix brochure - and 40 pages for the Marklin brochure - that would have made a full catalogue not that many years ago ... Scared Scared Scared Scared
But I don't see any coaches for th the Br15, were people thinking of the coaches for the EP3/6 ???Confused
#22 Posted : 15 April 2015 11:27:29(UTC)
Hi Alan,
They didn't make any Marklin coaches for the S2/6 either. I bought the Trix ones which were a good match.
I suppose any DRG Era II coaches will do for the Br15, or you could run it with the Orient Express coaches from the Main 2015 selection.
Offline NZMarklinist
#23 Posted : 15 April 2015 11:51:11(UTC)
NZMarklinist
Wot car set Confused
And did the 2/6 ever wear Black and Red, it still has red wheels tho to this day Wink Smile
The nicest little combo I see is the V80 and the Thunderbox cars with LEDs ThumpUp
The 01 is interesting but what will it's motor be ?????RollEyes Bored And what price for 1/999 Scared
Ok the EP3/6 looks very nice too, as does the 3 axle car set, Drool but I'm supposed to be modelling Era III, aren't I Blushing Confused
so I'll go the V80 and Thunderboxes, yeah boring I know Flapper but at least, I don't have a V80 Blushing
That said, I've heard a lot of earlier model Marklin 3 axle cars give trouble on turnouts, but then you don't believe what you've heard or do you RollEyes
Edited by user 15 April 2015 17:38:34(UTC)  | Reason: typo
Glen
Auckland NZ
Offline Andrey
#24 Posted : 15 April 2015 13:13:29(UTC)
Andrey
Russian Federation
Offline biedmatt
#25 Posted : 15 April 2015 14:07:55(UTC)
biedmatt
The V80 is interesting, but I do not know about the current conducting couplers. At first glace they seem appealing, but I had Swedish set 28703 where the loko had current conducting couplers. No matter what I did I could not stop the lamp flicker in the coaches, a problem when you directly use the switched output of a decoder and the rails as the positive return and not the common positive of the decoder. Perhaps they are switching center rail through a relay to the couplers, then all you need is a bridge rectifier in the coaches to stop lamp flicker, but I doubt they did.
The added light functions and sound though do make the V80 quite tempting. I have two of the older V80s (with Trix MTC21 circuit boards so I could install LoPi decoders) and they seem pretty plain compared to this new version.
The four new era 3 steam engines, very nice, but I have several versions of each and like Glen I question what motor these will come with.
Edited by user 15 April 2015 23:22:45(UTC)  | Reason: Not specified
Matt
Era 3
#26 Posted : 15 April 2015 17:55:29(UTC)
Summer new items - Delivery date.
00/2015 - Month/Year.
37069 - Q3
37516 - Q2
36082 - Q3
37016 - 08/2015
39007 - 08/2015
37920 - Q4
37950 - Q4
37864 - 06/2015
37338 - 08/2015
43131 - Q3
43320 - UNKNOWN
44113 - 09/2015
44250 - 06/2015
44734 - 09/2015
46088 - Q3
46536 - 05/2015
48515 - 11/2015
48817 - Q4
60884 - 05/2015
thanks 7 users liked this useful post by steventrain
Offline Marius in Africa
#27 Posted : 15 April 2015 19:06:49(UTC)
Marius in Africa
...............That said, I've heard a lot of earlier model Marklin 3 axle cars give trouble on turnouts, ............ RollEyes
Hi Glen
I am experiencing trouble with modern day Brawa three axle coaches on my layouts R1 curves and turnouts. I assume three axle wagons is not friendly towards R1 curves and turnouts. They will not be on my shopping list.
Marius in Africa
thanks 1 user liked this useful post by Marius in Africa
Offline Joseph Meiring
#28 Posted : 15 April 2015 19:28:12(UTC)
Joseph Meiring
37016 detail -
Highlights:
One-time series.
Thanx Steven - I must say I fancy that S 2/6 - 37016 - Will it be in the same price range as 37015 do you think??
Thanks for all the updates....ThumpUp
Joe
thanks 1 user liked this useful post by Joseph Meiring
#29 Posted : 15 April 2015 19:33:10(UTC)
37016 detail -
Highlights:
One-time series.
Joe
Check the Euro price on the German version of the brochure. I always grab a copy of the German version of the various brochures so i can get a feel for the prices in Euros, and figure how that is going to translate into the local currency.
#30 Posted : 15 April 2015 19:36:45(UTC)
Hi Glen
Hi Marius,
I have several Marklin 3 axle coaches of both the early Prussian types and the rebuilt DB types. All go perfectly through my C track R1 curves, curved and straight turnouts.
I can't speak for other brands, but if you get the proper wheels for them they should also work OK with Marklin track of all radii. Are you using your Brawa wagons with original DC wheels or replacement AC types?
#31 Posted : 15 April 2015 20:45:01(UTC)
37016 price about 40 euro less that 37015.
37015 did came with wooden box cost 30-40 euro extra.
Offline Andrey
#32 Posted : 15 April 2015 21:08:44(UTC)
Andrey
Russian Federation
I found prices for almost all Summer new items in Lokshop.
37016 Bavarian S 2/6 - RRP 479,95 euro
37069 Bavarian EP 3/6 - RRP 299,95 euro
39007 BR 01 Limited edition 999 pieces - RRP 449,95 euro
Already listed in Lokshop.
thanks 3 users liked this useful post by Andrey
Offline petestra
#33 Posted : 16 April 2015 01:13:09(UTC)
I really like the 37516 BR56 Freight steam Lok and the two Wagen milk car set 48817. No prices yet on these from Lokshop. Peter Smile
Offline baggio
#34 Posted : 16 April 2015 04:06:13(UTC)
baggio
One thing I like about Marklin is how humble they are:
Fascination that Comes from Perfection
What Does Märklin Quality Really Mean?
Märklin products were and are technical tours de force
before which engineers and other experts tip their hats.
They are unique in their kind. They are proof of the highest
level of technical ability and of technical perfection that
their peers seek. The creative standard is high and com bines
a wealth of detail and sturdiness into one.
A bit of a hyperbole, you said? OhMyGod
#35 Posted : 16 April 2015 06:39:22(UTC)
Marius in Africa
Marklin marketing speak which translate into a huge amount of BS!
Marius in Africa
#36 Posted : 16 April 2015 09:41:31(UTC)
Both are MHI items, It might be 10% discount.
#37 Posted : 16 April 2015 10:37:01(UTC)
Marklin said C-tracks wide curved turnouts, long double slip etc is not ready until in the fall 2015.
Offline Modelleisenbahnfan
#38 Posted : 16 April 2015 10:40:58(UTC)
Modelleisenbahnfan
the summer new items for H0 are great! ThumpUp
Soon, I will have my first mfx+ loco. I'm very excited. It's surely very interesting.
kind regards
Robert
Märklin, what else?
thanks 3 users liked this useful post by Modelleisenbahnfan
Offline MalinAC
#39 Posted : 16 April 2015 11:12:08(UTC)
MalinAC
Ireland
Is that 2 wagen milk car set # 48817 anything like the # 48815 set which I have. I tried to bring it up on a serch of internet but it keeps showing the 48815 set. Take care Eddie Huh Huh
thanks 1 user liked this useful post by MalinAC
Offline MalinAC
#40 Posted : 16 April 2015 13:13:42(UTC)
MalinAC
Ireland
Cancel that request as I found the file to download. Eddie
Offline jeehring
#41 Posted : 16 April 2015 17:33:53(UTC)
jeehring
kind regards
Robert
Yes, for me a pleasant new list ....
It was long!
Please , anyone to know exactly which color is the DRG S 2/6 model ?
PS , just read the announce on the catalog, the answer is : " black "...(hum...hum)
Edited by user 17 April 2015 15:16:00(UTC)  | Reason: Not specified
Offline Shamu
#42 Posted : 17 April 2015 12:07:00(UTC)
Shamu
Oh dear, I've been a naughty boy again......... just placed a order for a 39007 for €339.
About €30 less than I paid for the S2/6.
Just have to hope the Aussie dollar doesn't go down the toilet before it hits the shops. Sad
Edited by user 18 April 2015 02:44:56(UTC)  | Reason: Typo & edit
thanks 3 users liked this useful post by Shamu
Offline MalinAC
#43 Posted : 17 April 2015 13:21:15(UTC)
MalinAC
Ireland
Hey Shane, If you want you could send it to me so SWMBO wont see it and I promise to take very good care of it . I could even send you pictures of it on my humble layout. I may as well dream here . Take care Eddie Cool Cool BigGrin BigGrin
thanks 2 users liked this useful post by MalinAC
#44 Posted : 17 April 2015 20:08:15(UTC)
Price shown 37516 - 386,90EUR but Yellow light on database.
This page was generated in 1.472 seconds.
