Offline StuartA
#1 Posted : 13 April 2015 23:33:36(UTC)
StuartA
I have here for repair a 39025 BR 18.3 steam locomotive. The motor is fine, but the worm (which is machined with the flywheel) is worn out (stripped). The part number for the motor/flywheel/worm assembly is E231479, and is no longer made by Marklin.
Now I see in the spare parts diagram for the similar BR 18.3 item number 39024 there is a motor/flywheel/worm assembly number E163818, which is indicated as being available from Marklin. The question is this, is this motor unit compatible with the electrical circuitry in the 39025?
Thanks!
Stuart
#2 Posted : 14 April 2015 09:26:02(UTC)
Hi Stuart,
Drop an email to the Marklin service centre and ask them. They are fairly good at answering questions like that.
#3 Posted : 14 April 2015 10:16:11(UTC)
Hi, Stuart!
Another important question: do the physical dimensions fit?
The electrical circuitry should be no problem. The 39025 is the older loco, still with SDS. Standard decoder plus SDS motor driver. Remove the SDS motor driver and you should have a decoder suitable for the motor from 39024.
The decoder is crippled and may not support the load regulation parameters you need for best performance.
SDS is a small motor. With other locos they modified the mould to allow usage of other, bigger motors (BR 218 comes to mind). I have a 39024, but I don't have a 39020 or 39025 for comparison.
Märklin Service often reply "No" when it can be done with a bit of grinding.
This page was generated in 0.361 seconds.
