Offline IsItDigitalAlready?
#1 Posted : 30 March 2015 15:58:53(UTC)
IsItDigitalAlready?
To establish a programming track on my layout (controlled by a Roco/Fleischmann Z21) I would like to use a spur as a programming track. Has anyone found a solution to insulating an M-Track connection using a commercially available product?
Of course the center rail connector is easy to isolate (and I have plenty of tracks where the connector tongue is broken off). But the rails, being almost 3mm tall (about 0.118", or "code 118"), and made to Marklin's profile rather than standard USA rail profile, make me wonder what size (and brand) will work.
Also, since I only need two of these items, I don't want to have to buy a bag of 144 for $15.00 (or whatever) - a couple of bucks, tops!
Bob
Cold Springs (Reno), in far Western Nevada
It's all Gordon's fault!
#2 Posted : 30 March 2015 16:19:44(UTC)
You can cut the outer rails and fill the gaps with glue.
AFAIK many people do this for contact tracks, but this can also be done for the programming track.
Yes, insulating rail joiners sound like a good idea.
Current K track is code 100 and it seems there are insulating H0 joiners from Roco or Fleischmann. Just hearsay, I never tried them.
Or use C track for the programming track ...
Offline NZMarklinist
#3 Posted : 30 March 2015 16:25:57(UTC)
NZMarklinist
And Atlas, I have some Blink
Glen
Auckland NZ
#4 Posted : 30 March 2015 16:40:34(UTC)
IsItDigitalAlready?
I would rather not cut the rails - and, of course, the M-Track metal base would provide continuity anyway.
OK - so code 100 it is. I guess.
I'm going to San Jose next weekend and maybe The Train Shop will have them - I'll take a piece of track with me so I can be certain!
Bob
#5 Posted : 30 March 2015 17:18:04(UTC)
You were asking about M track but I have written about K track. Sorry! Blushing
Use old pieces of M track - maybe you can make the rails compatible with rail joiners using small pliers.
Plan B: Remove the rail joiners and screw the M track pieces tightly to the ground.
Plan C would be transition tracks to C track or K track.
#6 Posted : 31 March 2015 13:59:59(UTC)
Peco also do them.
#7 Posted : 31 March 2015 14:01:49(UTC)
Another alternative is to have the programming track as a completely seperate track, not connected to the layout at all.
#8 Posted : 31 March 2015 14:54:36(UTC)
IsItDigitalAlready?
I will definitely have that on the workbench, but I also want one on the layout.
Bob
#9 Posted : 31 March 2015 15:23:05(UTC)
NZMarklinist
Honestly Bob, from what I have learned around Marklin Digital for 10 years, reading & hearing about other peoples experiences with M Track you are on a hiding to nowhere trying to do what you are doing with M Track.
Make a brave decision and build your layout in C or K track, you'll be pleased you did in the long run !. C Track in particular is very digital friendly as is K track ! I am building my layout in K Track but intend to use C for the hidden Station ! ( Lots of Computer and digital contacts down there ! )
I had M track when I was a kid and yes it's nostalgic, and maybe cheap, but that's about all ! It won't be cheap when a dead short circuit fries your Z21 Scared
Glen
Auckland NZ
#10 Posted : 31 March 2015 15:42:15(UTC)
IsItDigitalAlready?
Thanks for the heads-up, Glen, but "I know what I'm doing." Confused
I did consider the alternatives to M-Track (of which I have a ton). I am not in a position at present to chuck all that and replace it with (really beautiful) C-Track. Besides, how hard could it be? Cool
In defense of my approach, I have two prmary things going for me (IMHO): experience with the vagaries of M-Track, albeit on analog systems, and an utter lack of arrogance regarding my abilities - "Double-Check" is my middle name. I also have some analytic skills, as well as training and experience (oh so long ago) in systems engineering, so I tend to be cautious and conservative. [need pocket-protector smiley]
Hmmm... Maybe we need an M-Track/DCC forum?
Bob
thanks 1 user liked this useful post by IsItDigitalAlready?
Offline Graham HO
#11 Posted : 01 April 2015 03:14:08(UTC)
Graham HO
Take a small piece of notepaper - not much larger than the central contact tongue. place it over the lower tongue - then push the track ends together - job done works every time.
#12 Posted : 01 April 2015 03:26:34(UTC)
In order to set up a safe programming track on a layout using M Track, I would recommend that you find a pair of the 7339 manual signals. Each set came with two half sections of track, one with a signal and the other with a isolated centre rail. To set up a safe programming track, you should position the first signal at the beginning of the track and the second a few track lengths along. This will create an isolated zone that is neither part of the main layout, nor of the programming track. Trains can be driven into this safe zone while the first signal is green and the second red. This allows you to drive into the section. Once the locomotive is within the section, turn the first switch red, isolating the section from the main power. You can then switch the second switch to green, which will then allow you to control the locomotive for programming. Once programming is completed, manoeuvre the loco back into the isolated section, switch both signals to red. You can then switch the first signal to green and control the loco via the main controller (layout) again.
If you use only a simple cardboard divider between main (layout) and programming track, you can damage the equipment due to the voltage that is transferred from one system to the other as the slider contacts both sections at the same time.
The two isolated half-sections can be used at other points along the layout where you need to interrupt the centre power studs. Alternately, you can place one of the isolated tracks between the two signals, which will create an absolute division between main and programming sections to avoid the possibility of both green signals being mistakenly activated.
Offline Hoffmann
#13 Posted : 01 April 2015 04:04:11(UTC)
Hoffmann
Hello Bob,
What you are looking for is Marklin M-Contact Track # 5105 it is the same length as a Standard Straight Piece and has a short Insulated outer Rail, see Picture
Hoffmann attached the following image(s):
marklin-eh
#14 Posted : 01 April 2015 08:09:37(UTC)
You picked the right date for your post. LOL
This thread is about rail joiners, not centre rail tongues.
The TO needs insulation on inner and outer rails (both outer rails).
#15 Posted : 02 April 2015 05:56:35(UTC)
Originally Posted by: Hoffmann Go to Quoted Post
Hello Bob,
If Bob is setting up a programming track as he mentioned in his first post, the track that you refer to will NOT be of any use.
That track has a small section that is isolated from the rest of the metal and track so that when a uninsulated wheel passes over it, it completes the circuit and can be used to activate a relay (e.g. for a road crossing or signal). This track will not interrupt the voltage between one end of the track and the other.
If you want to separate a programming track from the main line, you need to isolate the centre rail as I described above. You do NOT need to isolate the rails from each other.
My solution above offers the best transition from main line to programming track and there is no need to isolate the rail sections as long as the third rail is isolated. The danger that I mentioned of a voltage spike when the slider contacts both main line and programming track can be averted by using the two signal zone between the two power sources. This can equally be done without signals by simply setting up an independent power supply for the isolated section that can be powered by either main line or programming track with a two way switch (Main line - Programming). to avoid direct change from one to the other.
http://ecx.images-amazon...images/I/418dqHr1p2L.jpg
If I am missing something here, somebody please explain why you would need to separate the rail sections (isolate them from each other) to use a programming track? I have not worked with the Roco controller, but if using it to run DCC on Maerklin M- Track, you should be able to have a common ground without danger.
If it is required, my recommendation would be to use a M to C track adapter and then snap off the appropriate contacts at the C Track end of the rail. If you want, you can then connect back to M Track on the other side of use C Track for the entire programming track.
#16 Posted : 02 April 2015 08:10:53(UTC)
Nope, no common ground here. Central Station and Central Station 2 also require full insulation (centre rail and outer rails) to set up a programming track. IIRC same applies to Intellibox.
I would probably use a pair of 24951 transition tracks with four pieces 74030 in between (buy 2x 24951 and 1x 74030 - many dealers may sell the 24951 in pairs).
The other option I might try is the "air gap": two M tracks without rail joiners, screwed down tightly with a folded sheet of paper between them while fixing the screws.
Offline Shamu
#17 Posted : 02 April 2015 12:29:53(UTC)
Shamu
Hi Bob,
Just a thought but do you have a turntable ? Might be able to do something with one of the spurs.
Offline biedmatt
#18 Posted : 02 April 2015 13:31:35(UTC)
biedmatt
An air gap is probably the best route for all tracks, especially M.
I'd make the program track a section of the main line. Run the loko, decide the change desired, stop on the program track, make program change and run again to see if you got the desired results. The isolated program track allows you to program one loko while leaving others on your layout. The re-write is only transmitted to the program track, not the whole layout. When it is easy to make changes, you'll make them instead of just call it "good enough". The program track (at least with ECoS) has the same short circuit protection as the mainline, so it doesn't have to be some section stuck out of the way.
Matt
Era 3
#19 Posted : 03 April 2015 14:15:41(UTC)
I had arrived at this same conclusion, insert a small amount of C track into the M track layout. The cost will be minimal, and you will have an ideal programming section.
Offline el Gato Gordo
#20 Posted : 11 April 2015 19:19:34(UTC)
el Gato Gordo
Are we over-engineering this? Why not paint the rail ends and insides of the joiners with clear nail polish, let dry thoroughly, join the two pieces of track and test for continuity? At the low voltages we use, that should break conductivity.
Just an idea, Bro'
Gord
#21 Posted : 11 April 2015 20:30:28(UTC)
Maybe a small bit of thin plastic or more "nailpolish" between the railbed edges too in addition to the "nailpolish"at the joiners.
#22 Posted : 14 April 2015 02:49:58(UTC)
For M Track, simply coating the rail ends and the joiners with nail polish will not suffice, as the entire trackbed is part of the ground (return). The best option would be to use a pair of M-Track to C-Track conversion tracks and simply to cut the contacts that pass the current from one C-Track section to the other, which would create a 100% isolated break between the two. You should also make sure that you can safely isolate the power supply of the programming track (cut off switch) so that voltage is not transmitted into the output connection as a locomotive or train moves across the bridge from one section to the other, as both the metal wheels and the slider can bridge the two sections that you are trying to isolate.
#23 Posted : 15 April 2015 13:02:33(UTC)
el Gato Gordo
Mike - With the Z21 system that he is using, there is a Main lead and a Programming lead. Both can be left hooked up at all times, and trains run directly onto and off of a programming track without any difficulty. The only need for isolation is when actually doing programming. I am using the Z21 system on my N scale track that way.
Gord
thanks 1 user liked this useful post by el Gato Gordo
#24 Posted : 15 April 2015 15:43:11(UTC)
This is not specific to the Z21. It's the same with Central Station, ESU ECoS, Intellibox, ...
#25 Posted : 15 April 2015 16:45:34(UTC)
NZMarklinist
Hello Bob,
Sorry I did not see your reply before. On my analogue M track layout in my youth, insulating the centre rail was as simple as a small piece of thin cardboard, probably from a cigarette packet Scared (Lung cancer took my Mother at age 62 just 30 years ago last month Crying )
The outer rails, well, you could remove the joiners or "fish plates" as they are called in 32/1 scale, however if the track bases are touching there will be contact, so you'll need to invent a way, or create a permanent gap, to ensure isolation ! However traction tyres don't like gaps in the rails Blink
No we don't need an M Track DCC forum, you'll be about the only contributor Bored
Best of luck ThumpUp
Glen
Auckland NZ
#26 Posted : 15 April 2015 17:04:30(UTC)
el Gato Gordo
Okay, it seems obvious for now. Insulate the center tongue with a piece of paper, remove the rail joiners, and cut a piece of thin cardboard to the profile of the roadbed to insert between the two pieces of track. Screw down the two pieces with the cardboard between, and the problem is solved. No special track, no nail polish, etc.
When he gets back from vacation (can a retired person really be on vacation? how does that work?), he'll be able to proceed.
Gordon
Offline marklinrunner
#27 Posted : 23 May 2015 18:52:04(UTC)
marklinrunner
Hi Bob,
I have done this by using 2 plastic rail joiners to isolate the outside rails. I then cut a small piece of hard plastic ( I just used a piece of the hard plastic that come wrapped around everything we buy today) and inserted it between the 2 sections of track. This completely isolates the ground. You know how to isolate the center rail. I then installed a 2 way switch so that in one position normal track power was provided but not programming and in the other position programming but not power. This way you will never have the programming and track power on at the same time to this section of track. I will attach a couple of pictures to show the rail joiners.
Carlo
marklinrunner attached the following image(s):
#28 Posted : 23 May 2015 18:58:18(UTC)
IsItDigitalAlready?
What brand/model plastic rail joiners did you find that worked for you?
Bob
This page was generated in 1.558 seconds.
