Offline BwanaJoe
#1 Posted : 06 April 2015 19:16:37(UTC)
BwanaJoe
As newbie still trying to figure out digital I have a quick question. If I'm using a CS2 with the latest software and plan to use the mfx signals and digital turnouts is there a reason to buy the K83/84 decoders?
#2 Posted : 06 April 2015 19:25:06(UTC)
If the turnouts do not have the built-in decoders then you will need a k83 or m83 for four turnouts - cheaper than the decoders that go under the trackbed.
Offline BwanaJoe
#3 Posted : 06 April 2015 20:20:10(UTC)
BwanaJoe
And after wiring them up they would be programmed the same way?
#4 Posted : 06 April 2015 20:32:06(UTC)
Yep. Some have DIP switches, some are programmable - you find both types with single decoders and quad decoders.
Makes no difference when you use them with a CS2 or other controllers.
Offline BwanaJoe
#5 Posted : 06 April 2015 22:42:25(UTC)
BwanaJoe
Well, I love cost effective stuff. Any difference between Viessmann and Märklin?
Quad decoders?
Oh, would the K83 be driven off its own transformer? Ditto the turn out motor?
#6 Posted : 06 April 2015 23:32:03(UTC)
Quad decoders?
Decoders like k83 for four turnouts.
The new m83 60831 has some advanced and unique features.
If you only want to operate turnouts, then a k83 (6083 or 60830) will do that fine - just like Viessmann decoders or those from other brands. And Viessmann 52111 is rather affordable.
Power for turnouts comes from the decoder.
k83 can be modified to allow external power, m83 and third party decoders usually are prepared for it.
To get started you can operate turnouts from track power with all decoders.
This page was generated in 0.389 seconds.
