Offline Modelleisenbahnfan
#1 Posted : 03 April 2015 17:49:08(UTC)
Modelleisenbahnfan
let's assume that I want to make a double heading with two same Märklin-locos. One has a mfx-decoder and the other a mfx+-decoder. Could I use the mfx+ layout then for both locos? (With the CS2, of course.)
And if the two same locos have the same motor, can I use the same values of the cvs for the mfx-decoder and the mfx+-decoder?
I'm looking forward to helpful answers
kind regards
Robert
Märklin, what else?
#2 Posted : 03 April 2015 18:21:43(UTC)
Difficult...
Someone did present diesel V100 in two difference catalog number and both locomotive do have same motor,but decoders value wasn´t in same way!!
#3 Posted : 03 April 2015 23:05:40(UTC)
Double-heading is for me, a matter of trial and error.
I put both locos on the track a couple about 20cm apart, then use CS controller for each, and see how well the speed matches.
Adjust the controller for one, until it matches the other, then couple together.
You can then double head them using two control knobs.
If you want to consist them, so both are on the same controller, do the same test regards speed match.
Then you may have to change the speed values for one loco, in the CS, to match.
#4 Posted : 04 April 2015 00:50:15(UTC)
Robert,
If you are referring to using the CS2s "M.U.Set" mode to configure a consist, then the answer is currently no.
The resultant "master" reference of the M.U.Set that you use to drive the locomotives, does not inherent the mfx+ settings and therefore the CabMode option is not available
#5 Posted : 04 April 2015 02:19:21(UTC)
It is very easy if you use computer control like WinDigiPet, because you "profile" your locos to create a speed curve (or line in the case of two of mine) that WinDigiPet uses to set the decoder to a particular speed. Over the holidays I will a videoing my party trick of running two locos around my layout at exactly 1cm apart.. its a hoot..
Of course, there are provisos about how well this works. Using a brand new loco and a Delta with a half-seized engine is not going to work well at all! Laugh
Offline Janne75
#6 Posted : 04 April 2015 08:45:34(UTC)
Janne75
This is a little off-topic, but I have an easy solution to run two of my SBB Crocodiles double heading... Only one has it's SDS motor installed BigGrin . Other one runs very easily behind loco with motor just rolling on the track. All functions can still be controlled. My Finnish Märklin dealer offered me this 39563 Crocodile without SDS motor. With original box and instructions etc. for only 50 euro! It looks still great on track and in display cabinet.
I have used M.U.Set with my digital sound wagons for diesels and steam locos. Good way to buy a loco without sounds or just one sound and add one of these wagons to get 10-15 sounds.
Janne
#7 Posted : 04 April 2015 18:51:33(UTC)
Modelleisenbahnfan
thanks for your replys.ThumpUp
I've one question: What do you mean with "M.U.Set"?
kind regards
Robert
Märklin, what else?
#8 Posted : 04 April 2015 19:00:11(UTC)
I presume M U means Multiple Unit in this case.
Not marklin users... Wink BigGrin
#9 Posted : 04 April 2015 19:23:40(UTC)
"Mehrfachtraktion" in German. Menu item "Neue Traktion anlegen" in the German CS2 UI.
#10 Posted : 04 April 2015 23:04:27(UTC)
#11 Posted : 06 April 2015 10:10:31(UTC)
Modelleisenbahnfan
thank you for the explanations!ThumpUp
kind regards
Robert
Märklin, what else?
This page was generated in 0.531 seconds.
