Offline Moritz-BR365
#1 Posted : 24 March 2015 08:51:50(UTC)
Moritz-BR365
the AC version of the Roco ET 485 comes with a standard pickup shoe, similar to the Märklin pickup shoe. But it is very easy to replace it by a silent pickup shoe. It need only a few modification. With some parts from the Roco pickup shoe and from the Märklin silent pickup shoe E144133, a new silent pickup shoe is created within a few minutes.
This is the original one from Roco
Here, You can see the original one and Märklin E144133
Remove the plastic plate:
Place the plate from Roco into the one from Märklin:
Now cut the middle part from Roco:
remove the lower part of the pickup shoe to be able to reach the screw and place the cutted part in the middle:
and screw it in tight:
Then reassemble the removed lower part:
Here, You can see, that the pickup shoe has full space to deflect:
#2 Posted : 24 March 2015 20:21:15(UTC)
Would it not have been simpler to simply use the Roco Flusterschleifer, which replaces the original part in the Roco catalogue?
http://www.roco.cc/de/se...sterschleifer/index.html
http://www.roco.cc/de/pr...0-0-006001/products.html
The same design is currently also used by LS Models and other manufacturers.
Offline waorb
#3 Posted : 24 March 2015 20:44:35(UTC)
waorb
Brazil
Hello.
In my subjective perception, I think this "new" silent pickup shoe isn't so reliable... short answer I prefer the old ones...
I have a few loks with this kind of pickup shoes and sometimes I feel that the loks fails to get the energy from the tracks...
This "perception" doesn't occurs on loks with the olds...
It's something only on my mind, or it's for real?
Also, this new ones seems to be more fragile... if you push/pull 1% more, they already bend...
Opinions? Unsure
Walter
(sorry for slightly push the subject off-topic...) RollEyes
#4 Posted : 24 March 2015 22:12:51(UTC)
Moritz-BR365
Hello Mike,
the Roco 40500 has a price of 11,40€! The Märklin one is available for 1,95€. The second point is, that You can see, that the screw will have no contact to the pickup shoe. Therefore, You need a part like I used to create the contact, too.
And last point, the Roco silent pickup shoe is to wide! It doesn't fit into the available space, because of this damn black plastic around. The Märklin silent pickup shoe fits perfectly with 5,3mm wideness, the Roco silent pickup shoe is 8mm wide!
Moritz
#5 Posted : 24 March 2015 22:15:33(UTC)
Moritz-BR365
Hello Walter,
I got no problems with the silent pickup shoe. It works better than the old style ones. And, it is much more quiet! With slow and medium speed, I can't really hear the pickup shoe on the Märklin M-rails.
The silent pickup shoes are worth, especially when You are using sound locos. And they have great electric contact, because they are more flexible.
Offline waorb
#6 Posted : 25 March 2015 13:29:54(UTC)
waorb
Brazil
Hello Moritz!
Well, on this days I have only C-tracks... decades ago was M-tracks... maybe yes, on M-tracks the noise could be more annoying...
But that is the point, the flexibility... to me both parts (the gold and silver) isn't so tight connected... the pieces are a little loose among them.
I have at least one lok with this kind of pickup shoe: 37549 - Steam lokomotive Serie 4600 (ex Baureihe 55)
This one uses the part number E138079 (instead of yours E144133). From photos on the internet, seems that they are slightly diferent - something that's not worth it.
I remember that I needed to bend it a little, little bit to make a 'V' instead of leave it original flat... so the lok could get energy all the time...
Perhaps I need to get used to this new kind of part... RollEyes
Walter
This page was generated in 0.295 seconds.
