Offline Karl Audenaerde
#1 Posted : 06 March 2015 22:54:41(UTC)
Karl Audenaerde
My CS2 60215 is hooked up to a Netgear WiFi extender. Using this connection to update the CS2 software works fine, so the connection itself should be OK. I downloaded the Marklin MobileStation app and it connected to the CS2 - for about 30 seconds. Since then I get "Not connected to CS2" no matter what I try. The phone runs iOS8.1.3 and it's IP address is 10.0.0.50; router address is 10.0.0.1.
The CS2 version is 2.43. Under the IP tab I find (I think) the correct settings:
IP addres: 10.0.0.50
IP Mask: 255.255.255.0
IP Gateway: 10.0.0.1
DNS Server: 75.75.75.75
The CAN gateway starter is set at "auto," and the target address is 10.0.0.255 (I tries other values, but without result). Confused Confused Confused Blink
Help!
Offline tulit
#2 Posted : 07 March 2015 01:27:31(UTC)
tulit
Help!
The IP of your cs2 shouldn't be the same of that as your iPhone. Try setting it to 10.0.0.49 instead- or something nothi else on your network is using (or use dhcp)
#3 Posted : 07 March 2015 14:46:20(UTC)
Karl Audenaerde
DHCP did it. I should have thought of that, but got thrown off track after reading (and misinterpreting) the article in Volume 23, Number 2 (March-April 2011) on the subject, Thank you so much!
This page was generated in 0.352 seconds.
