Offline johnmarklin
#1 Posted : 01 March 2015 18:14:33(UTC)
johnmarklin
Ireland
Hi All,
I am looking for your assistance. I bought a Marklin Z Gauge 88731 set new a number of years ago and put it in storage pending the construction of a layout. I took the set out recently to run it but found that it will not run properly for me. The motors work and the wheels turn but the railcar will not move nor will it change directions. Any suggestions?
Offline ozzman
#2 Posted : 01 March 2015 19:37:20(UTC)
ozzman
Assuming you mean that the set as a whole will not move, you have to realise that, for reasons best known to themselves, Marklin designed that set (and others like it) to run as a whole, with the cars connected by power conducting couplers. If only one of those couplings doesn't conduct power, the train as a whole won't work - in the way that you describe. To compound a crime with a felony, the power conducting strips that form part of the couplers are quite fragile.
It's possible that, while assembling the set on the track, you accidentally bent one or more of the conducting strips. Assuming my diagnosis is right, you might be able to repair the offending coupling(s). Otherwise you'll need to order new ones from M*. A few months ago they were out of stock.
You have a set there that looks great, but it has poor electrical design. I am in the same position...
Gary
Z Scale
Offline johnmarklin
#3 Posted : 03 March 2015 23:43:32(UTC)
johnmarklin
Ireland
Gary,
Thank you for your reply. The connections are in good shape, motors work when the complete set is connected up but the wheels slip on the rails and the set just stays put. It is a mystery, I will keep on experimenting.
Offline ozzman
#4 Posted : 04 March 2015 04:29:33(UTC)
ozzman
It sounds as if the two power cars are pulling in opposite directions, something I've seen before. What the cause is, I don't know. Maybe you could take it up with Marklin?
Gary
Z Scale
Offline johnmarklin
#5 Posted : 08 March 2015 18:15:57(UTC)
johnmarklin
Ireland
Thanks Gary,
I will investigate further.
This page was generated in 0.359 seconds.
