Offline scissorsnm
#1 Posted : 22 February 2015 20:59:55(UTC)
scissorsnm
Has anyone had trouble with the Marklin 74490 switch motors only working on one side. I have two cantankerous motors that I can't figure out why they won't work at all at times and at times just one way. I have taken them out of the layout and they work fine just grounded on on piece of track hooked up to an out side transformer. They, when working, seem to just move the points to the straight side but not to the turnout side. Same thing happens wether they are hooked to a switch decoder or through a K 83.
Any suggestions as to where I may look.
#2 Posted : 23 February 2015 00:25:02(UTC)
When fitting them to the track don't do the screws up tight. Nip the screws tight then back then off a quarter turn. The motor should then have the slightest movement available on the screws.
If up screw the screws tight then the body of the motor can get ever so slightly distorted and the armature jambs and won't move. Taking thm off the point relieves the stress and they move again.
While you are at it, put a drop of solder across the microswitch connections. The microswitches are notorious for going faulty and can give a similar problem, but as you say they work fine when you take them out I doubt these are the problem. However it is not impossible that there is a faulty solder joint on the microswitches that fails when the PCB is stressed by being screwed in, but makes contact again when taken out.
Offline scissorsnm
#3 Posted : 23 February 2015 04:49:35(UTC)
scissorsnm
Thanks Alan... I'll try what you suggested.
Offline sjlauritsen
#4 Posted : 23 February 2015 17:34:42(UTC)
sjlauritsen
Before you "fix" the point motor by dropping solder onto the microswitch, which will of course work, try contacting Märklin about the problem. They usually just let you send the faulty motors to them and you get brand new ones in return. If you "ruin" them with solder, you loose this option.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
This page was generated in 0.367 seconds.
