Offline PeFu
#1 Posted : 10 February 2015 19:00:30(UTC)
PeFu
Designing my new layout, I will start from the bottom... I'm interested in a hidden/shadow station with a similar design as below from member laalves. Access to the station should be double track, 77.5 mm distance. As I'm pretty new on C tracks, I would love to get article numbers... Any suggestion of C track plans?
Btw, are there any c track building kits on the market, for building the helix?
BigGrin Peter
PeFu attached the following image(s):
#2 Posted : 10 February 2015 22:18:59(UTC)
The curved 30º track pieces look like 24130 (R1).
The straight track can be either 24172 or 24188.
The 24.3º R2 turnouts are 24611 (left) and 24612 (right).
The curved 24.3º track pieces to "counterbalance" the turnout are 24224.
http://www.maerklin.de/m.../c-gleis_kataloginfo.pdf
German MRR trackplan archive:
http://www.moba-trickkis...tenbank-gleisplaene.html
Maßstab = scale: select HO
Größe = surface: select desired size
Booklet for download:
http://www.mediafire.com...ple%20from%20Marklin.pdf
For helix (German:"Gleiswendel") see here:
http://www.noch.de/de/pr...anlagen/gleiswendel.html
http://www.gleiswendel-p...87/Maerklin-C-Gleise-24/
Offline Mark5
#3 Posted : 11 February 2015 03:28:11(UTC)
Mark5
Great info as usual Ak,
Can you clarify that link?
It doesn't click through for me.
- Mark
Offline pab-windmills
#4 Posted : 11 February 2015 04:36:40(UTC)
pab-windmills
Hej Peter,
If you have basic skills with a jig saw, making a helix should be no problem for you. I would recommend simply using 9mm plywood and R2 or R3 radius pieces. Figure out the minimum clearance you want between the helixes, and use threaded rod with nuts and washers to space the helixes.
Lycka till, Paul
thanks 2 users liked this useful post by pab-windmills
#5 Posted : 11 February 2015 09:35:10(UTC)
Originally Posted by: Peter Funck Go to Quoted Post
...Btw, are there any c track building kits on the market, for building the helix?
BigGrin Peter
Hi Peter,
Noch sell complete plywood helix kits for use with C track.
Start with their kit number 53001 for R1, it works for M, K, or C track.
This is complete with separation pegs, and gives you 1.5 circuits.
53004 is for double R1/R2 tracks.
53009 is for double R4/R5 tracks.
This is the instruction overview diagram that comes with kit 53004.
kimball
#6 Posted : 11 February 2015 11:44:57(UTC)
- Mark
Grrrrr, the link is indeed "dysfunctional" now. Seems like the doc was withdrawn. And I did not keep a copy of the download. Sorry for that.
#7 Posted : 11 February 2015 11:51:48(UTC)
Originally Posted by: pab-windmills Go to Quoted Post
Hej Peter,
Lycka till, Paul
Here a nice example of a gent who did that, using it for his temporary "Teppichbahning":
http://www.extrem-teppic...page2/page49/page49.html
BTW, photo #1 with the drill illustrates how he used that power tool to ease the tiring task of "rotating" the nuts.
Offline biedmatt
#8 Posted : 11 February 2015 11:57:22(UTC)
biedmatt
Here is a helix kit from Istanbul. I think he has a single track helix too, but it is a bit pricey.
http://www.ebay.com/itm/...&hash=item43c7491df2
Matt
Era 3
Offline biedmatt
#9 Posted : 11 February 2015 13:28:04(UTC)
biedmatt
LOL Yeah, I liked that too!
Matt
Era 3
Offline PeFu
#10 Posted : 17 February 2015 02:14:58(UTC)
PeFu
Thx for all your input! This is what I came up with so far... On this "bottom" level, the layout space is approx. 350 x 130 cm. The hidden station will have 6 tracks, each of approx. 136 cm length. I plan to use R2 and R3 in hidden areas, R4 and R5 - and the 24912 piece - in visible areas.
Would you have any "smart" solutions to narrow the space on double-track, from 77.5 mm to 64.3 mm?
BigGrin Peter
File Attachment(s):
Hidden Station with Reversing Loop.pdf (33kb) downloaded 77 time(s).
Offline PeFu
#11 Posted : 17 February 2015 11:03:08(UTC)
PeFu
Nevermind my own question on how to get from 77.5 to 64.3 mm; I found this great description on http://lucy-michael.klen.../hobbys/modelleisenbahn/
BigGrin Peter
#12 Posted : 17 February 2015 13:32:35(UTC)
There are many alternatives. Here is another one. As train movements over the changeover from straight track to R1 in the lower right hand corner do not look nice (unimportant in hidden area), I would prefer a wider radius there as R2/R3.
#13 Posted : 09 February 2016 22:39:01(UTC)
Found a German MRR helix specialist:
http://www.gleiswendelshop.de/
#14 Posted : 20 January 2017 20:34:30(UTC)
I've got their solution (not yet assembled). To make the postage worthwhile (as its a bit and heavy package), I ordered a 5 cycle + a 3 cycle helix kit. This way I can build an 8 level or make two 4-levels, or other combos. Once I get my flooring in place and can build up the helix (as it won't fit out the door once assembled ) I'll start experimenting to see how many loops I need to get the height change I need.
Its well made, smooth edges, all hardware included.
#15 Posted : 22 January 2017 20:27:28(UTC)
Don´t ask what the helix can do for you, but ask what you can do for the helix.
:o)
http://www.stummiforum.d...;t=125158&start=1000
Offline rbw993
#16 Posted : 24 January 2017 18:08:03(UTC)
rbw993
Wow the brandy the monks make in that place must be really powerful! Where can I get some?
Roger
Edited by user 26 January 2017 20:05:34(UTC)  | Reason: grammar
This page was generated in 0.651 seconds.
