Offline Robyn Boyd
#1 Posted : 07 February 2015 18:25:56(UTC)
Robyn Boyd
General question on the 6647 transformer (32 VA, 220 volts)
I was given a 220 volt transformer, and I wanted to know if I could step it down to 110 volts to use for lighting purposes. I run all analog locomotives on "M" track. Would I have to separate the lighting circuits (if that is even possible)? Could I also use it to run the locomotives or accessories at the stepped down voltage?
Thank you for your responses in advance!
#2 Posted : 07 February 2015 18:48:30(UTC)
You could supply it with 110V and you will get around half the voltage output. However you will not get the full wattage i.e. your 32VA will be down to around 8VA before the output voltage sags under load (you might still get satisfactory operation at 10-12VA). This is an inherent function of the limitations of the transformer.
So you won't be able to run many normal bulbs off it, the standard old Marklin bulbs were listed at 1VA each. However the bigger limitation is the maximum voltage you will get, so old type bulbs will glow very yellow/orange. Running LED lighting designed for 9-12V will be more successful, as it will also draw less current, and make the capability of the transformer go a bit further.
#3 Posted : 07 February 2015 21:24:35(UTC)
How about using a pre-stage 110V-220V step up transformer to feed the 6647?
Just a thought...
This page was generated in 0.379 seconds.
