Offline mascagni
#1 Posted : 02 February 2015 20:38:32(UTC)
mascagni
I bought the 29483 starter set. The two curved turnouts in that set have motors and decoders installed. They respond to the keyboard addresses 1 and 2 on the MS included in the starter set; however, I cannot get them to respond to my CS2 keyboard. Do you know why this may be the case?
I also do not want to have them permanently assigned to addresses 1 and 2, and they are permanently attached to the turnouts. There are no dip switches on the exposed side, so how do I change the addresses? I am used to using the Viessmann decoders, which are programmable, but you have to have access to their backsides for that. Do you how to change their addresses?
Thanks.--MM
Michael Mascagni, Tallahassee
#2 Posted : 02 February 2015 22:24:36(UTC)
Hi, Michael!
Make sure red and brown are not swapped at the track connection. Make sure CS2 is not set to DCC for turnouts 1 & 2.
DIP switches should be on the hidden side.
Offline mascagni
#3 Posted : 03 February 2015 17:07:13(UTC)
mascagni
The dip switches seem to be unavailable due to the plastic posts the decoder sits on being melted (riveted).--MM
#4 Posted : 03 February 2015 17:18:25(UTC)
Can you post a picture of the exposed side for comparison? To make sure whether it is a decoder with DIP switches.
Offline mascagni
#5 Posted : 05 February 2015 22:48:14(UTC)
mascagni
Here is a picture of the decoder, as requested.--MM
[img=https://www.flickr.com/photos/mvmascagni/15832345413]Turnout Decoder[/img]
Click Here
#6 Posted : 05 February 2015 23:24:19(UTC)
I don't see a picture: "mvmascagni doesn't have anything available to you."
Offline mascagni
#7 Posted : 06 February 2015 00:33:53(UTC)
mascagni
Please try now.--MM
Offline mascagni
#8 Posted : 06 February 2015 00:38:16(UTC)
mascagni
Offline Cyborg
#9 Posted : 06 February 2015 06:10:11(UTC)
Cyborg
Hi Michael,
It is not riveted onto the post. Just carefully pull it up from the 3 posts to expose the underside where the dip switches are located. The decoder is just pressed down onto those posts to secure it.
Paul
thanks 1 user liked this useful post by Cyborg
#10 Posted : 06 February 2015 07:57:03(UTC)
Yes. Sometimes they fall off as soon as you turn the turnout around, sometimes it takes a little force to get them off.
Offline mascagni
#11 Posted : 06 February 2015 14:58:51(UTC)
mascagni
This a test to see if I can embed the picture I wanted to embed in this post. It is only a test.
[img=https://content-na.drive.amazonaws.com/cdproxy/templink/Cy1TJkwX9ZndEfe6wrjXcibrO1UVF3jMweQW8Oq-gy8LAYspN?viewBox=1920]Turnout Decoder[/img]
Offline mascagni
#12 Posted : 06 February 2015 15:23:53(UTC)
mascagni
Amazon Cloud Drive, not so good, so here is from Google+? It worked, and the trick is to get the URL of the image that is shown.
GOOD!! I have several of my students working at Google, and they have served me well!!!--MM
Turnout Decoder
Thumbnail version of Turnout Decoder
Offline mascagni
#13 Posted : 07 February 2015 13:52:52(UTC)
mascagni
You were right, thanks!! Here is a picture of the decoder flipped over with the cell phone repair kit I used to gently pry it off the plastic posts.--MM
Turnout Decoder successfully pryed off with cell phone tools
This page was generated in 0.483 seconds.
