#1 Posted : 27 January 2015 02:28:26(UTC)
I am thinking of putting some signals on to the N scale Layout. I will use either Viessmann 4412 (3 Aspect) or 4413 (4 Aspect) Signals.
What would be the correct Viessmann or LTD Decoder Box to use and How many?
Thinking of about 6 - 8 Signals
Will be using ECOS and Itrain.
would be nice to be able to select address range.
Nev
#2 Posted : 27 January 2015 03:31:50(UTC)
The 4412 and 4413 signals are the equivalent of the 4012 and 4013 H0 signals. It all depends on what you want - do you want iTrains to start/stop the trains or do you want brake modules with isolated track sections to control trains.
If the former, all you might need is a 5210 signal module for each signal (in some cases you can run 2 signals off 1 module) plus a k83, or the later you might need the 5224 signal module plus a 5228 relay module and a 5232 brake module for each signal.
In any case, I've sent you a PM with additional info.
#3 Posted : 27 January 2015 03:37:06(UTC)
Thanks David,
I will be Using Itrain to do the stopping. I was thinking of using a Viessmann 5229 wHich I think will do all , but I think only 1 signal, so a lot of Gold for 8 signals???
I think a LDT may do 2 Signals,
If costs are high , may revert to a 2 aspect signal.
N
#4 Posted : 27 January 2015 04:37:03(UTC)
It is possible to use a k84 with signals....
#5 Posted : 27 January 2015 04:39:30(UTC)
How many 3 aspect signals will a K84 handle??
#6 Posted : 27 January 2015 05:39:45(UTC)
According to the Viessmann 5213 manual, you can run up to four aspect signals (stands to reason since a K84 has 4 relay connections). You could therefore have one 3 aspect signal or one 4 aspect signal per K84 or two 2 aspect signals per K84.
You could possibly consider a Marklin M84 as well - I haven't tried either a K84 or M84 with signals though.
Viessmann 5213 manual attached - see pages 4 and 5.
If you already have some V5213's you could get a signal or two and have a play with the setup.
File Attachment(s):
Viessmann 5213.pdf (264kb) downloaded 10 time(s).
#7 Posted : 27 January 2015 05:47:45(UTC)
M84 is what is in the Trix catalogue. DCC or Selectrix.. I am going to use the M83 for point motors. the Viessmann 5229 is about $50 plus postage. Eight 4 aspect signals makes a hole in the wallet. the M83 is a bit exe too.
may just go with 2 aspect signals
N
#8 Posted : 28 January 2015 02:32:42(UTC)
Had a Look at the LDT range of decoders as they are good value for money. each LDT unit can handle 2 x4 aspect and 2 x 2 aspect signals each. Good quality units.
Nev
This page was generated in 0.343 seconds.
