Offline sidblack
#1 Posted : 18 January 2015 02:05:58(UTC)
sidblack
Hi folks,
I'm building an analog layout. I'm using the 7211 control box for the first time but I can't get it to do anything. I've wired it according to this diagram. The wiring makes sense and when I join the two blue wires together they reform a circuit but when I connect them to the 7211 nothing happens.
Inside the control box there seems to be something missing (see photo) as there doesn't seem to be anything there to complete the circuit.Confused
Any suggestions please?
sidblack attached the following image(s):
Offline BrandonVA
#2 Posted : 21 January 2015 17:31:40(UTC)
BrandonVA
I'm a little confused about what you're using 7211 to achieve. Are you trying to power on/off a section (block) of track?
-Brandon
Offline sidblack
#3 Posted : 21 January 2015 21:42:52(UTC)
sidblack
Hi Brandon,
Thanks for getting back to me. Yes, I'm setting up a block of track. I've isolated the centre stud and then wired it according to the diagram. When I touch the wires together they reform the circuit so the wiring works but not through the 7211. I went to Jaycar and bought some basic on/off switches so I may use those instead.
This page was generated in 0.450 seconds.
