Offline stlcards54
#1 Posted : 17 January 2015 06:23:32(UTC)
stlcards54
Just spent all nite installing new lokpilot 4.0 and it actually worked! ms2 even recognized it auto in dcc. Then I said I'll put on my analog track. It worked, I hit reverse and bam it no longer worksCursing . As usual I read the manual after and it says the old blue transformers could blow the decoder. So is there a way to test the decoder to see if it's truly dead? Maybe using a voltmeter/ohmmeter?
#2 Posted : 17 January 2015 07:47:30(UTC)
You can measure the reversing voltage of your transformer. 28 V is the specified maximum voltage for most ESU and Märklin decoders (32 V for some ESU decoders).
Do not risk any other digital decoders if you read more than 28 V.
Offline Brakeman
#3 Posted : 18 January 2015 01:17:30(UTC)
Brakeman
According to ESU manual, Lokpilot 4 for DCC only, art. no. 54611, does not support analog power.
Which one did you have, DCC or multiprotocol?
Juha
thanks 1 user liked this useful post by Brakeman
Offline stlcards54
#4 Posted : 18 January 2015 01:27:04(UTC)
stlcards54
I had a 54610, it did work in analog until I tried to reverse it. Oh well, live and learn.
thanks 1 user liked this useful post by stlcards54
This page was generated in 0.249 seconds.
