Offline Gert-Jan
#1 Posted : 16 January 2015 20:30:26(UTC)
Gert-Jan
Hi everyone,
I have one car from this identical 3 pieces carset, 46900-2.
When it is pulled over a switch, the derails on the rear bogey (with the pickup shoe)
The rear bogy just twists a few degrees causing a shortcircuit afterwards.
Reason for derailment look like the pickup shoe is pushes the car upwards. The rear bogey might lose grip/track and derail.
The car itself isn't that heavy.
Also, the degree of movement from the rear bogey is very limited compared to the front bogey...but seems fine when pussed downwards over curves by hand.
Question: Any experiences with these cars anyone? I can not imagine it is brought to market this way, designed to derail.
Solution could be a new pickup shoe; Or I could put in additional weight under de car coal load...but it is a work-around to the issue.
Mosty era III DB.
Offline SteamNut
#2 Posted : 16 January 2015 20:38:48(UTC)
SteamNut
Adding additional weight is more common then one might think. There are standards for weights but Marklin does not follow them but at least it is a easy fix. Sometimes the shoe is loo low and adjusting to the correct height works, I had that on a slider under a tender and that took me a while to figure that one out
#3 Posted : 16 January 2015 21:14:01(UTC)
I have one of those Eaos cars, but have not used it yet. There is some circuitry hidden under the coal load, but there should be space to install some additional weight. I guess that you would have to use something that does not conduct electricity, to avoid any possible short of the electronics, but it should not be hard to do. The other possibility is to use current conducting couplers and have the slider on a more stable car.
#4 Posted : 17 January 2015 08:03:20(UTC)
I have a Silberling control coach by Märklin. Out of the box it derailed on every turnout when it was pushed.
I adjusted the pressure of the pickup shoe (reduced it, of course) until everything worked - no extra weight needed in that case.
Extra weight will probably also work.
Offline Gert-Jan
#5 Posted : 17 January 2015 11:04:34(UTC)
Gert-Jan
With the 'presumability' that Märklin designed and tested this to work 'as-is' I suppose adjusting the shoe pressure is the first option to try.
I had similar shoe-issue's with my BR 78 loc that simply could not cross a slim turnout. New pickup shoe simply fixed that.
I reckon you just 'bended' the shoe springs a little bit inwards?
Mosty era III DB.
#6 Posted : 17 January 2015 12:00:28(UTC)
Yep, bend the ends in the "up" direction (where "up" assumes the car is standing on the track).
Offline Gert-Jan
#7 Posted : 17 January 2015 13:13:07(UTC)
Gert-Jan
I will try...also giving the bogey more angle movement will help.
Pushing the wires a bit outside give more clearance and prevent that the bogey is twisted out of the rail.
Overall, it is a 'handmade' car seeing how it is constructed.
Gert-Jan attached the following image(s):
Mosty era III DB.
thanks 1 user liked this useful post by Gert-Jan
Offline Gert-Jan
#8 Posted : 18 January 2015 13:54:32(UTC)
Gert-Jan
Fixed it. The real issue was with the wiring that obstructed the bogey to rotate freely.
The wires are lead through the car's pivot point from the bogey. This must have been stuck somehow.
(I broke the wire anyway and had to re-well it)
Mosty era III DB.
thanks 4 users liked this useful post by Gert-Jan
This page was generated in 0.362 seconds.
