Offline mcnall
#1 Posted : 14 January 2015 17:37:36(UTC)
mcnall
I am Marklin newbie and need good graphics or video that show how to adjust the relex couplers, both older and newer. I have a nice old TM 800 with old style coupler and cars with mixed ols and newer style. I also have have the adjustment gauge but can't seem to get the hang of bending the coupler components correctly.
Offline Ken Mitchell
#2 Posted : 14 January 2015 21:29:15(UTC)
Ken Mitchell
Hello mcnall, do you have the instruction notes to go with the adjustment gauge? I have a gauge and supporting document. All of my marklin engines and carriages are pre 70s and i am working through them slowly. Regards Ken
Offline mcnall
#3 Posted : 14 January 2015 22:05:27(UTC)
mcnall
I do not have any instructions that came with the gauge. Would certainly appreciate getting any visual material on the adjustment process. Thanks
Offline Br502362
#4 Posted : 15 January 2015 07:19:17(UTC)
Br502362
Hi Smile
Maybe this helps you?
MÄRKLIN 7001
Åke
#5 Posted : 15 January 2015 10:16:05(UTC)
Hi Smile
MÄRKLIN 7001
Åke
All I get there is a Marklin gif image, it doesn't allow you to download the file.
Offline Shamu
#6 Posted : 15 January 2015 10:27:39(UTC)
Shamu
Hi Smile
MÄRKLIN 7001
Åke
Right click and "copy shortcut" then paste into address bar will see you right
#7 Posted : 15 January 2015 10:32:26(UTC)
Ken Mitchell
Will scan it at work tomorrow and get it to you somehow, either a post or email. Regards Ken
Offline Br502362
#8 Posted : 15 January 2015 11:29:21(UTC)
Br502362
HI,
A new try Confused
Åke
Br502362 attached the following image(s):
#9 Posted : 15 January 2015 13:37:59(UTC)
Ken Mitchell
The document i have has been attached by another group member. This should get you the usage of the gauge.
To set the height, I bend the coupling up or down at the coupling bend adjacent the carriage or engine, this if outboard of the coupling attachment pin. Use needle nose pliars and hold the coupling firmly to body attachment point.
To set the 12 to 15 degree angle on coupling, I have made a guide from cardboard with a vertical line from the base and two lines - one at 12 degrees and one at 15 degrees. I hold behind the gauge and coupling to see that i am in between the two angled lines. If not, use the needle nose pliars and bend the coupling buffer forward or rearward until you achieve the 12 to 15 degree recommended angle.
Regards ken
thanks 1 user liked this useful post by Ken Mitchell
Offline mcnall
#10 Posted : 16 January 2015 02:59:21(UTC)
mcnall
Thanks for the information. Worked on one car and adjustment is much better. Will definitely need to get some smaller needle nose pliers.
This page was generated in 0.552 seconds.
