#1 Posted : 13 January 2015 16:42:54(UTC)
about 20 years ago there was often a reference to using one of the wires in the booster connection to force an emergency power off of the Intellibox. At the time I had such a small layout that I never needed to add switches around the layout, but now with my new layout I will not be able to get to the IB fast enough if the need arises to shut things down quickly, so I am contemplating adding the emergency stop feature to the layout.
I seem to recall that one of the wires was a signal used by boosters to signal that a sort had occurred. By grounding this wire, one introduces a (false) signal indicating that a short has occurred on a booster and this results in the IB shutting off power.
Am I remembering this correctly?
Which wire is it?
Can anyone here remember this or have done it?
Any downside?
I know I could use an s88 feedback line and use that signal to shut off power using software, but that will only work if the software is running. The booster 'short' signal is pure hardware and always present.
I have some very industrial looking emergency stop buttons that I plan on using too!
#2 Posted : 13 January 2015 19:07:58(UTC)
Which wire is it?
Any downside?
I don't know off hand which wire it was, but it was in the cable to the 6015/7 boosters. I can't find my schematics at the moment, but that should put you on the track of it.
Offline perz
#3 Posted : 14 January 2015 21:49:21(UTC)
perz
It is pin 5. See the following image I found:
booster connection
thanks 3 users liked this useful post by perz
#4 Posted : 15 January 2015 15:29:36(UTC)
thanks perz. I assume this diagram is probably from some site explaining how to drive the digital signal directly from a serial port, and from it we can see that pin 5 is the stop signal line.
i.e. it is not showing anything about how to introduce the false short signal. I presume shorting pins 4 and 5 need to be bridged.
Offline tommycox
#5 Posted : 25 February 2015 20:52:33(UTC)
tommycox
I use an iPhone or an iPod Touch to as an emergency STOP button for my Intellibox. Would that work in your situation, Dale?
Offline tommycox
#6 Posted : 25 February 2015 20:56:20(UTC)
tommycox
Ummm... using JMRI/WiThrottle Lite of course. I forgot to include that.
#7 Posted : 25 February 2015 21:20:57(UTC)
Can I ask, why not simply install a few emergency-stop buttons around the layout directly wired across the track - you are not doing anything that a derailed train would not do if the wheels or slider short out the track?
Advantage to this is that there will always be a section of track nearby so you won't have to run wires back to the Booster etc.
But not owning a Booster myself (I do have an IB) there may be some aspect I have not considered - ie if you trigger a short on the IB, does that automatically shut off the Booster also, and vice-versa?
Always looking for simple solutions
#8 Posted : 26 February 2015 10:27:32(UTC)
Cookee, I suspect Tim may have this issue with his layout, given it is most likely much larger than Dale's (2300 sq ft)
#9 Posted : 03 March 2015 18:43:25(UTC)
I also have such software and mobile device control, but they suffer from a few disadvantages
a) they need to be in your hand and running when you suddenly need it. No time to switch apps, or navigate...
b) the software stack, connection to the central unit must work without delay.
#10 Posted : 03 March 2015 18:46:01(UTC)
Shorting out the track is NOT a good solution. There is a chance of frying the booster or IB itself. I also have fuses in the supply to these devices and they sometime blow before the booster-IB stack shuts off. I dont want to have to replace a fuse every time I make an emergency halt, and certainly dont want to fry the hardware either.
Online H0
#11 Posted : 03 March 2015 22:51:18(UTC)
Hi, Dale,
I'm pretty sure I once saw how an emergency button can be connected.
IIRC it had to connect one pin from the 5-pin booster socket with one pin from the 3-pin booster socket. Both sockets have turn-off pins, but with opposite polarity (Märklin vs. rest of the world).
I spent some time on Google, but couldn't find the page again.
#12 Posted : 04 March 2015 00:54:33(UTC)
Hi Dale,
Appreciate the response but I'm really none-the-wiser. Right from the early days of Digital there was plenty of information that short-circuits need not be feared on a digital layout because the reaction/shutoff time of the controllers was so fast that damage would not result.
I appreciate that the original query was probably more based on stopping an "about to happen" incident in which case what you really want is a button that simulates the 'Stop' button on the controllers. If equipment is so fragile (or poorly designed) that a derailment, or something dropped across the track causing a short actually fries the equipment, I would seriously consider avoiding those products.
I've shorted many times through derailments and never has any item suffered resulting damage.
Derailments on a model railway are a fact of life and the control equipment should be absolutely impervious to it.
We can of course agree to disagree, we're all gents here afterall but I'd be REALLY interested in a factual proven incident of a typical short-circuit actually causing damage. The only time I could see it not possibly being effective would be a derailment that unfortunately happened across an isolated section between two controllers/boosters? - even then, the designers should still be anticipating the possibility of the worst-case scenario.
These are afterall products aimed at a market which includes children who make mistakes.
Given that your recollection is from maybe 20 years ago or thereabouts, I wonder if it might have been an article in Tom Catherall's Digital Newsletter or similar?
Interesting topic all the same. For me, I'd still pursue a button to short the track (pending further good reasons why this is a really bad idea)???
Steve
#13 Posted : 04 March 2015 01:59:53(UTC)
On the other hand, I lost my Intellibox when there was a short on my 6017 boosted section.. And I know that I am not the only one to lose an Intellibox this way.. So while the majority of shorts are harmless, the Intellibox/6017 combination does require more caution.. Perhaps the signal to the Intellibox from the booster is too slow or perhaps the signal itself is a "boosted" voltage? So I understand where Dale is coming from with this idea.
#14 Posted : 22 March 2015 16:27:54(UTC)
I run an IB and two boosters. Each has a fast blow fuse on their power supply.
I add the fuse because I would rather replace a cheap fuse than fry a booster or the IB.
My tracks are are well connected, i.e. if there is any short, lots of power can flow. On a number of occasions, a short has resulted in the fuse blowing.
Since there is a digital signal line that indicates that there has been a short, it is obvious that one should use that rather than producing an ACTUAL short which forces one to rely on the current cut off of the devices, no matter how well they are designed. Shit, it may even be cheaper to lets the trains collide than short out the electronics!
Anyway I am still on the hunt to find out exactly which line of the cable should be grounded.
#15 Posted : 06 May 2015 22:26:28(UTC)
I pinged long time Mäklinist John J McVeigh and got this answer:
If you create a short circuit (e.g., by means of an SPST momentary-contact pushbutton switch between either Pin 1 or Pin 2 of the IB's Booster port and Pin 5 of the same port, this should cause the IB to believe that there is a short-circuit on the track in a Booster-fed power district, so that the IB should go into protective mode.
Pin 5 of the Booster port is the one that is closest to the s88 port. Pin 1 of the Booster port is the one that is furthest away from the s88 port.
This page was generated in 0.638 seconds.
