Offline Moritz-BR365
#1 Posted : 12 January 2015 11:06:03(UTC)
Moritz-BR365
here, I present my conversion of my Märklin ÖBB 1020.02 to LED head and rear lights. There is also a new mainboard to plug the motor, LED-boards, buffer capacitor and the decoder.
I converted this model a few years ago from analog to digital with Ersu LokPilot V4.0 DCC, later I changed the motor to HLA 5-pole and a few days ago I equipped ball bearing to the motor shield.
LED head lights
There are original spare parts for the 3922x-series which may be compatible with my 3159. But I decided to create my own LED board:
To have enough space and good light separation, I sawed the fiber optic into two parts.
LED head light assembled
Head light with LED
Rear light with LED
The LED head light board got a micro plug. I created this with socket board and shrink hose.
Mainboard
The main board has sockets for the two head light LED boards (LV and LH), for the decoder (8-pole plug), for the buffer capacitor (switchable for programming), the motor and for the cabin lights. There is space for four resistors for the LED head lights, too. I used 2.4kOhm, but I will replace them with 5.1kOhm, because the light is still very bright.
[IMG][/IMG]
The electric GND connection is secured by the mass cable to the motor but also by the screw on the mainboard, which holds the mainboard in place. I use the same holder which is formerly used by the driving direction switch.
For this, I soldered a shim on the circuit board, connected to the black cable connector of the decoder socket. You can see the shim on the middle of the left side of the circuit board.
Not yet ready are the AUX amplifier, the cable for AUX3/4 on the decoder, the buffer capacitor and the AUX2 is not yet connected (purple). Also, the second head light LED board is not yet soldered!
Edited by user 23 October 2015 20:52:05(UTC)  | Reason: Not specified
thanks 6 users liked this useful post by Moritz-BR365
Offline mmervine
#2 Posted : 12 January 2015 13:33:37(UTC)
mmervine
Fantastic job!
thanks 1 user liked this useful post by mmervine
#3 Posted : 12 January 2015 16:14:28(UTC)
Excellent job as usual!
Congratulations
I like the idea of mounting the connectors "tilted" to provide a little more clearance!
That's an idea I will definitely use (As you know, plagiarism is the sincerest form of flattery....BigGrin )
Now comes my questions:
1)what are you planning to use the AUX3/4 outputs for?
Telex? Lifting pantographs?
2) what technique did you use to cleanly cut the light conducting insert?
Small table circular saw?
Jacques
#4 Posted : 12 January 2015 17:37:17(UTC)
Moritz-BR365
Hello Jacques,
Congratulations
Thanks!Smile
AUX3/4 will be used to switch the driver's cab light:
To saw the fiber optic, I used a standard jigsaw. Afterwards, I polished the surface with a polish tool in my drill press until it was mostly free of scratches.
Moritz
#5 Posted : 12 January 2015 18:48:28(UTC)
Thanks....more good good ideas !!😁
Offline Alberto Pedrini
#6 Posted : 12 January 2015 21:29:16(UTC)
Alberto Pedrini
Don't forget the red light on the cab, if you want to do something other.
obb
Only Roco makes the correct lights... Crying scroll down the page
http://www.marklinfan.net/obb1020.htm
Alberto
Marklinfan Club Italia
www.marklinfan.net
thanks 2 users liked this useful post by Alberto Pedrini
#7 Posted : 13 January 2015 08:05:00(UTC)
Moritz-BR365
Hello Alberto,
I know, that the Märklin 1020.02 is not very true to original. But that doesn't matter, I own this loco since over 30 years! Nothing else matters.
I don't know, for what the red light on the cab is used for, it is not used in German railway signal book. It would be possible, to drill a hole there, because there is a pit on the Märklin model. It would be easy, to drill the hole very precise. But then, my decoder has not enough AUX ports.
About Roco, sorry, I rather like heavy metal locos. I bought an E94 yesterday - Märklin 39221 with C-Sinus motor - a dream!
#8 Posted : 13 January 2015 08:28:53(UTC)
Moritz-BR365
Next LED board for the other side:
Some details must be resoldered, not yet finished...
Edited by user 23 October 2015 20:53:12(UTC)  | Reason: Not specified
#9 Posted : 13 January 2015 08:29:01(UTC)
Hello Alberto,
For the heavy metals,i am with you.ThumpUp ,but please do not drill this beauty.Scared
#10 Posted : 16 January 2015 08:40:48(UTC)
Moritz-BR365
Here, some additional pictures after finishing the second LED board and fitting the mainboard into the loco
I had to change the position of the mainboard, otherwise, the connectors and cable from motor and LED board wouldn't fit with the case mounted on the chassis:
Here, You can see the buffer capacitor with 1.100µF, enough to buffer short power breaks:
On the left, the micro plug for the motor, below the same for the LED board. The micro switch is to disable the buffer capacitor, which is necessary for programming the decoder.
On the right the single plug is from the buffer capacitor, below the 3-pole plug from the LED board:
The loco is now ready to run. The last step will be to enable AUX3/4 for the drivers cab lights.
Edited by user 23 October 2015 20:56:32(UTC)  | Reason: Not specified
thanks 3 users liked this useful post by Moritz-BR365
#11 Posted : 23 October 2015 20:58:18(UTC)
Moritz-BR365
Restored the pictures, because the formerly used links were broken.
Guest (4)
This page was generated in 0.413 seconds.
