Offline Janne75
#1 Posted : 27 December 2014 15:54:32(UTC)
Janne75
I have many originally LFCM motor equipped locos modified with 60944 5-pole motors and permanent magnets. They are still without decoders. Have anyone tried to use 60760 kits decoder (intended to be used with DCM 5-pole motors) with 60944 motors? I would like to try this combo, but if someone knows this is an absolute no-no, please let me know. I just thought if this could be possible? Confused I will get better decoders to most of my 60944 motor kit equipped locos, but maybe some 3021´s could have this decoder. RollEyes
Janne
Edited by user 31 December 2014 23:57:43(UTC)  | Reason: 60760 decoder should work ok with 60944. I will try it.
Offline Janne75
#2 Posted : 31 December 2014 18:04:49(UTC)
Janne75
Someone must have tried this combo = 60944 5-pole motor (basically also DCM) and 60760 decoder. Does this combo work ok?
Happy New Year 2015! Cool
Janne
#3 Posted : 31 December 2014 18:22:29(UTC)
Hi Janne,
I have not personally tried it, but I don't see any reason why they should not be a good match. The 60944 kit effectively converts the LFCM into a DCM, with a similar size of armature, so there should not be any major difference in the dynamics of this motor to the DCM.
Try it and see, and please let us know how well it works!
On the other hand, this is only equitable if you already have these decoders left over from another conversion, as a 60942 MLD decoder is actually not very different in price from a 60760 kit. I think the difference is about 3 euros. The MLD decoder will give you MFX and more functions, apart from better speed performance.
#4 Posted : 31 December 2014 20:41:08(UTC)
I've used a 60760 decoder in a loco with a SFCM motor (it was a 3000) and that worked fine. I see no reason why a 60760 decoder would not work with a LFCM motor.
Try it and see, if it doesn't work well you can replace the decoder.
Offline mmervine
#5 Posted : 31 December 2014 23:32:22(UTC)
mmervine
I agree, it should work fine.
thanks 1 user liked this useful post by mmervine
Offline Janne75
#6 Posted : 01 January 2015 00:01:14(UTC)
Janne75
Thanks for the replys. I will try 60760 decoder with 60944 motor kit (LFCM modification motor kit to 5-pole DCM).
Happy New Year 2015! Smile
Janne
Offline Graham HO
#7 Posted : 02 January 2015 00:58:12(UTC)
Graham HO
Just had my LFCM Ae6/6 converted with 60942 and 60944 - can't fault the performance - so quiet and powerful. Will likely use 60944 on two other analogue loks, not cheap but you get what you pay for.
thanks 1 user liked this useful post by Graham HO
This page was generated in 0.472 seconds.
