Offline Kiwi01
#1 Posted : 21 December 2014 10:31:17(UTC)
Kiwi01
Ok so i went to give my trains a bit of a run earlier tonight after working on the layout but when i turnef it on the 6021 controller wasnt responding normally. It had all the function lights on and they wouldnt turn off and it wouldnt allow input of a loco address ie nothing happened when pressimg buttons. The lights on the loco were on the whole time so musy be getting some output at least. Hopefully someone can help!!
#2 Posted : 21 December 2014 10:52:17(UTC)
Did you try to reset the 6021 or power recycle it?
Offline Kiwi01
#3 Posted : 21 December 2014 11:02:21(UTC)
Kiwi01
Yup tried the reset using start stop buttons. Also tried tirning off the power and turning back on. Still doing same thing. Its previously worked fine but hasnt been run in a few months so not sure what's going on
Offline Renato
#4 Posted : 21 December 2014 11:07:00(UTC)
Renato
Have a look at this:
LINK
Hope this could help.
Renato
#5 Posted : 21 December 2014 11:08:40(UTC)
Where in NZ are you? Dion at Toottoot could probably repair it for you. Forum member (Peter) Clapcott at the Marklin Club here in Wellington has also repaired a few 6021's in his time, so might also be able to help.
The most common fault with the 6021 seems to be that the output transistors often blow. Replacements are available.
Offline Kiwi01
#6 Posted : 21 December 2014 18:48:41(UTC)
Kiwi01
Im located in nelson. Is there ant reason they often seem to have this fault? Pleased to hear its easily repaired though!
Offline stevend
#7 Posted : 21 December 2014 22:14:14(UTC)
stevend
Hi, yes I can fix this for you. Send it to us in Christchurch. We have moved. Check our website www.toottoot.co.nz for the new address.
Looking at the comments it might be more than the output transistors.
Kind Regards
D
#8 Posted : 21 December 2014 22:27:02(UTC)
I have one 6021 where the buttons have gotten very stiff. The unit still functions, but you have to press really hard to get the key to register. I have seen this on old remote controls, usually when liquid or finger oil gets into the buttons, but this 6021 was never damaged. It came from a 29859 set around 2001. A few buttons still work like new, but some of the function keys and number pad are almost useless.
Since the lights on the train are still working, this suggests that the problem may not be the output transformer, but something else. Have you tested all of the keys to see if it may be the same issue that I have?
CS1 and 6021 issues,.. (Digital)
by kbvrod 11/10/2012 20:48:22(UTC)
This page was generated in 0.299 seconds.
