#1 Posted : 18 December 2014 03:36:09(UTC)
DO NOT UPGRADE YOUR CS2 using your PC until you follow the instructions below:
ENGLISH version
There has been a new software-program for the PC-version of our central station on our website since dec. 11th, 2014.
Programname: Installationsprogramm CS2.exe Version 3.8.1(11)
Although we tested this program carefully, the installation-routine may have a problem under specific cirumstances. Also data on the PC not used by this software may be deleted when you try to uninstall the software.
In case you downloaded the software during the period of dec. 11th and dec. 16th 2014, please proceed as follows:
DO NOT UNINSTALL the program from your PC – please wait for further information
Do not install the program on your PC, if you have downloaded, but not installed so far.
We are working very hard to provide a repair-program. This will be available within the next days at this specific place (where you usually find our updates):
http://www.maerklin.de/d...ds/software_updates.html
Please follow any instructions there and do not uninstall the current version.
The repair-program will be available as an update for your PC, named cs2_setup.exe in version 3.8.1(12). This update has to be installed without uninstalling the current version from your PC.
Details of the bug:
Problem occurs within the initial start of the program on your PC, when using the default directory as working directory for the central station program and then uninstalling the program via the uninstall-routine.
In this case the data of central station program on the PC BUT ALSO further User Data will be deleted from the PC.
IMPORTANT: The bug occurs only in the PC-version for CS2 software 3.8.1, which allows an extension of the Central Station to your PC screen (CS2.exe version 3.8.1(11) dated dec. 11th 2014). The core CS2-update 3.8.1, dated dec 2nd 2014 is not affected.
This same message was posted by Steventrain in the Digital Topic thread and can be found here:
https://www.marklin-user...Central-Station-CS2.aspx
DO NOT INSTALL THE UPGRADE as the software runs an unistaller to remove previous versions that can also delete registry keys and file associations that may be required to run other software as well. Please follow the instructions provided by Maerklin or wait for the next upgrade.
This page was generated in 0.271 seconds.
