Offline frank.constantino
#1 Posted : 18 December 2014 03:04:52(UTC)
frank.constantino
I just bought a 3469 BR E19 loco on eBay and it has no manual. Right now I am using an infrared controller from a starter set which controls the four delta addresses. For some reason I am unable to get the new loco to run. I have tried what I thought was the correct way to change the address of the loco. Can someone tell me
1. How to change the address on this loco to one of the Delta addresses?
2. Is there something else that I'm missing.
The loco is getting power because if I flip the switch on the underneath of it (I assume to run it in analog) it runs uncontrollably at full throttle.
Thanks so much!
-Frank
#2 Posted : 18 December 2014 04:28:32(UTC)
If you open the loco you will find the delta decoder with four little switches,there are 4 options to run the loco.
1.You must turn the first switch on and the other three in position off.
2.First and second on and third and forth off.
3.First and thirs on and second and forth off
4.First and forth on,second and third off.
I hope i help you.
#3 Posted : 18 December 2014 04:52:40(UTC)
Propably you will choose the option number 4 and you will select with the delta controller the icon with the electric locomotive.
#4 Posted : 18 December 2014 05:10:23(UTC)
frank.constantino
Thank you. That worked perfectly. I am new to Marklin!
#5 Posted : 18 December 2014 06:33:56(UTC)
Wellcome aboard,glad I help you.ThumpUp
This page was generated in 0.426 seconds.
