Offline georgi411
#1 Posted : 08 December 2014 16:31:40(UTC)
georgi411
Please can you tell me how to conect the Viessmann 5217 (s88) to the CS2,CS2 60215 has the last software, In the screen of the Station show if this is conected? Have any indication?. When the train pass the contact track that is conected to s88 the signal supposed to change the signal or the track? Thank you
Offline Fredrik
#2 Posted : 08 December 2014 16:53:52(UTC)
Fredrik
Have you added a track-component with feedback-Connection to the layout screen?
If not, you have to put one of these (at least) on the screen to see any response from the S88. The Component needed is a straight, or diagonal, track with a circle in the middle. When placing this component you will be asked to enter address of connected feedback-contact (1-16 for S88 #1, can't remember if module # must be entered too). The circle will light up yellow once S88-contact is activated. Current CS2 implementation (afaik) don't allow complete tracks to light up (red), which would be better...
Also - don't remember if it's neccessary with the Viessmann 5217 - but guess it is: You have to connect the S88 to ground (0). For this use one of the upside-down "T"-marked connectors. Only 1 (usually the first) S88-module needs this connection.
Fredrik.
WWW: MJ-fjärren
This page was generated in 0.431 seconds.
