Offline Hackcell
#1 Posted : 04 December 2014 04:46:56(UTC)
Hackcell
Costa Rica
I'm trying to update the sound files on a 60946 decoder and when I click on Upd the CS2 returns the following message:
The transfer is not possible at the moment. CV access is obvioulsy running. Please try again later.
If I try to check the loco CVs it says Locomotive "V 200 060 DB" gave no feedback. Try again?
I can't even change the loco address as the address appears grayed out. I can't even configure the loco as a DCC loco because it doesn't recognizes the default DCC address.
After several tryes, the CV returns to me as hardware version 0.0.0.0.0
Any ideas if this is something that I can fix or shall I change the decoder?
Thanks.
Danilo Jiménez
Costa Rica, pura vida!!
Offline sjlauritsen
#2 Posted : 04 December 2014 05:17:58(UTC)
sjlauritsen
What I would do:
Make sure the decoder talks DCC and not MFX? It it talks MFX it will not react to DCC commands - not even if you create it as a DCC locomotive. The address will be grayed out if it is an MFX locmotive.
If it is an MFX locomotive, create it again as DCC and go to settings to turn MFX off.
If the above did not work:
Then, I would check if I could read another locomotive. Just to get an idea on how big the problem is.
Either case: I would then restart the CS2, just to make sure any cached values will be cleared out.
If the problem is only with one particular locomotive:
I would probably delete the locomotive and create it again with the settings that I wanted.
If that did not work, I would contact Märklin about the problem regarding the locomotive.
If the problem is with all my locomotives:
I would contact Märklin, because I would suspect my CS2 to be weird.
I would most likely also restore the latest working backup. Just in case the problem is database related. A restore would most likely fix the problem.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
#3 Posted : 04 December 2014 08:13:07(UTC)
You never could change the mfx address coz mfx addresses are assigned by the CS2 and cannot be changed.
Make sure the CS2 is not on STOP and that mfx feedback works fine. As Søren wrote, the loco will not respond to DCC if mfx is activated in the decoder.
A re-boot may solve the issue.
You can put the loco alone on the programming track. You may have to remove the radio interference suppressor thingie between CS2 and track - some of them also filter the mfx feedback.
This page was generated in 0.255 seconds.
