Offline Andreas K
#1 Posted : 03 December 2014 12:11:53(UTC)
Andreas K
HI All
I have more than 15 steam locos on my layout at any given time, all have sound and the sound is turned on.
The majority of these loco’s either stand at a yard or on a siding waiting for a signal to turn green (on a breaking relay).
At this stage these loco’s only have “back ground sounds” e.g. steam being released or coal being shuffled.
What I noticed is that if the CS2 (60214) stop button is press and pressed again to start, all loco’s sounds cycles are synchronized.
What I mean by this, all 15+ loco’s release steam at exactly at the same time or coal is also shuffled at exactly the same moment.
Is there a way to set the sounds on a more random time per loco so that if power is restored to the tracks the different loco’s have sounds on different times?
Any help will be appreciated.
Best Regards
Andreas
Pure Marklin - Steam is my Passion
#2 Posted : 03 December 2014 13:00:04(UTC)
Originally Posted by: Andreas K Go to Quoted Post
HI All
Best Regards
Andreas
Hello Andreas,
What a fantastic layout with >15 steam locomotives making sound !!
More video with sound please!
PJ
#3 Posted : 03 December 2014 13:09:21(UTC)
Hi, Andreas!
You can set the minimum and maximum duration between these "random" sounds. Varying these intervals between locos will bring them out of sync.
There may still be some doing the same sound at the same time for the first random sound after a stop, but the time difference should increase from random sound to random sound.
Offline Andreas K
#4 Posted : 03 December 2014 14:35:55(UTC)
Andreas K
Hi, Andreas!
Hi Tom
Thank you very much, where do you do these changes?
Best Regards
Andreas
#5 Posted : 03 December 2014 16:41:45(UTC)
mfx locos? I hope you have a Central Station. With CS2, open loco properties, click "CV" and look out for suitable entries. It'll be a few days until I find time to search the correct entries.
Offline franciscohg
#6 Posted : 03 December 2014 18:52:38(UTC)
franciscohg
Chile
Hi, took a quick look and did not found such option in the presetted pages of CV config on the CS2, there are some options in German, maybe there....
Will take a deeper look later
#7 Posted : 05 December 2014 10:05:54(UTC)
I took screenshots of the real Central Station and the CS2.
Bad news: it seems that only mfx decoders with manufacturer ID 151 (ESU) support this while decoders with ID 131 (TRIX) do not.
Screenshots were taken with a Märklin BR 220 with the factory-installed mfx decoder.
Offline Andreas K
#8 Posted : 05 December 2014 11:18:39(UTC)
Andreas K
Hi Tom,
Thank you very much for your time and effort, much appreciated.
Kind Regards
Andreas
Offline franciscohg
#9 Posted : 05 December 2014 12:05:55(UTC)
franciscohg
Chile
So....that is why I could not find the option.... XD
Will check some ESU decos later to test it
This page was generated in 0.422 seconds.
