Offline biedmatt
#1 Posted : 30 November 2014 17:26:31(UTC)
biedmatt
When your motor starts to fail after the soft brushes and lubricant begins to short the commutator segments, you might be able to save it.
Squirt a bunch of this into a coffee mug. It, or similar, can also be found in 1 gallon cans.
Now run the motor for a few minutes. You will begin to see the junk start to settle to the bottom of the mug. See it on the right side of the mug? Yes, the can states the product is highly flammable. So be sure the motor is completely covered in the solvent and then turn on the power. Turn the power off too before you remove the motor. This keeps the sparking brushes away from O2 so it will not ignite.
Do this at your own risk. It works fine for me. Your results may vary.
Matt
Era 3
thanks 6 users liked this useful post by biedmatt
Offline biedmatt
#2 Posted : 30 November 2014 17:36:12(UTC)
biedmatt
Of course, do this at your own risk. It works fine for me, your results may vary.
Matt
Era 3
Offline Chook
#3 Posted : 01 December 2014 06:36:39(UTC)
Chook
Matt I am waiting for John to "arc up' on this one.
Actually I have not seen him post for some time now which is quite out of character??
Regards......Chook.
This page was generated in 0.547 seconds.
