#1 Posted : 24 November 2014 09:19:37(UTC)
I am about to install 2 x M83 together. I know that they are connected by the 9 pin connectors, each decoder has its range set by the dip switches,
Power will come from the track. ( Have 4.8 amps on a N scale layout).
question do I need to supply track power to the second Box or does only One need to be connected to track power.
Using a MS2 (trix coloured knobs and tminitrix locos.
thnkx,
Nec
Offline Hackcell
#2 Posted : 24 November 2014 19:44:03(UTC)
Hackcell
Costa Rica
thnkx,
Nec
You should be able to connect both using the power coming from the track in just one of the 60831. I have 2 connected without any issues.
Danilo Jiménez
Costa Rica, pura vida!!
thanks 1 user liked this useful post by Hackcell
#3 Posted : 24 November 2014 21:43:41(UTC)
thnkx,
Nec
Thanks Danilo. The answer I wanted. Thought that may be the case.
Nev
#4 Posted : 29 November 2014 23:47:25(UTC)
From page 16 of the user manual
Several m83/m84 decoders can be plugged together with the side plug contacts. No extension or connecting wire may be used for this. All of the decoders plugged together are supplied with power from the power connections (power supply or track connections) made to the first turnout decoder. No other track connections may be made.
What is not clear or identified is what the meaning of the term "first turnout decoder".
If an external power source is deployed it will prevent additional baying of units in that direction (because the plug is in the way) therefore it can be inferred that this is the "first turnout decoder".
Because the diagrams at the top right of the page are illogically placed, I would revert to words and say the "first turnout decoder" is the rightmost of a chain if you are looking at them and the DIP switches are away from you.
P.S. Warning.
Baying of these units may not be a good idea if you are expecting to do programming/reconfiguration with a MS2. Because the MS2 does not have PoM capability for static decoders, it can only perform global programming - thus , to program an individual m8x you must isolate all others from the circuit.
#5 Posted : 30 November 2014 00:01:06(UTC)
P.S. Warning.
Peter, thanks, I dont think I will be programming, just setting the dip switches on each one to get the address range. also as I will be using track power I think I will use a Laptop power supply IF I can use it without smoke escaping.
nev
#6 Posted : 30 November 2014 01:58:27(UTC)
Hi Nev,
You do mention N-scale and a 66950 (Trix MS2) and MiniTrix Locos
However you have not mentioned what you are actually using the M83 for?
When considering (re)programming it is not just the desire to change the device - but the effect on the device if changing OTHER devices.
If, for example, you do the initial address setup for a DCC loco on the track with the MS2 , then it will also overwrite a m8x (if in DCC mode).
#7 Posted : 30 November 2014 02:29:16(UTC)
Hi Nev,
I will be using the M83 for digital addressing and operating Point motors.
I will take note of that little quirk when programming. I may set up a programming track and use a double pole 3 position switch to turn off main lines and send to the Prog. track. easier than removing power from the M83.
Thanks, for that.
Nev
Online Goofy
#8 Posted : 30 November 2014 09:02:58(UTC)
thnkx,
Nec
Hello Nev!
4.8 amps is to much power for the N scale.
So you should reduce to 2-2.5 amps.
Small locomotivs are sensible if short circuits happens and 4.8 amps will boost out yours locomotivs.
By the way...how did you got 4.8 amps for the MS2?
Märklin reccomended only 1.9 amps.
Online Goofy
#9 Posted : 30 November 2014 09:10:10(UTC)
Hi Nev,
That´s way there is an safety push button for programming adresses of the turnout decoder.
After you did programmed,just simple push button programming off by finish.
When you have locomotivs on the tracks and programming,the turnout decoder is not react.
Nev should have tried first with Lenz LS150 to test it.
I use it and they are great!
Goofy attached the following image(s):
This page was generated in 0.444 seconds.
