Offline sjlauritsen
#1 Posted : 15 November 2014 10:30:33(UTC)
sjlauritsen
I have a 60174 booster and a 60061 power supply. I noticed yesterday, that an overload situation occurred with a BR 141 (Trix #22143), where the booster did not detect it. Apart from some smoke (from the power pickup external resistor), the loco is fine and works without problems. No damage was done. I was, however, kind of puzzled on why the situation was not detected?
I have tested several different overload situations with that same locomotive during the setup phase. I have never seen this happen before. Neither have I been able to reproduce the problem. Normally the overload detection kicks in at around 5 seconds after the overload begun (a bit long time for my taste, but I have not found a way to change that).
In my investigation on the problem, I noticed that the booster settings was set to use a 60101 power supply. I changed this to the 60061. I then wondered if perhaps this had something to do with the problem.
My question is: Does the booster change its overload detection to match the power supply that it is setup to use? Meaning that a setting at 60101 would tolerate a larger load than a setting at 60061, even though the power supply is a 60061.
Søren from Denmark
Offline Shamu
#2 Posted : 15 November 2014 12:10:04(UTC)
Shamu
Interesting question Søren,
It would not be beyond the realms of possibility that the settings for a 60W-v-100W PSU may make a difference to the time-out for the overload protection BUT without a accurate circuit diagram and any relevant code that may or may not be in a on board PIC its anyone's guess.
Although I'm inclined to think that a sudden overload/short would be dealt with in well under 5 seconds. This is something I will have to look into for my own curiosity.
Shane
#3 Posted : 15 November 2014 13:29:51(UTC)
That's why you select which power supply you have.
There was a time when the CS2 had different software versions - one for transformers (AC), one for DC power supplies. Different parameters for overload detection.
If the booster is set to turn off at 5 A (that's what you get with a 60101 setting) and you use a 3 A power supply, it's no surprise that the overload protection will be triggered with a delay.
This page was generated in 0.256 seconds.
