Offline Crocodile
#1 Posted : 11 November 2014 11:40:31(UTC)
Crocodile
Well finally received the MA 3423, LSE T 141 Wismar, Delta Digital. Seems to run OK; however I'm using it as shuttle using 2 circuit tracks (to auto change directions) and S 88 with CS 2. Going forward ok. Nicely stops at point A and reveres to point B. however runs right through point B stopping only after hitting track bumper with wheels still turning. Only after manually touching reverse arrow on CS 2will loco reverse & resumes route back to point A. Upon arrival at point A, auto reverses nicely bacs to point B running, again straight thru point B hittling track bumper.
Substituting a BR 221 loco, for a test run on circuit tract, loco gracefully stops a points A & B and reverses as it should making a perfect shuttle.
Can't figure how to get Wismar to stop and reverse at point B to complete auto shuttle route.
Any advice/suggestions would be appreciated
#2 Posted : 11 November 2014 12:53:33(UTC)
The earlier types of decoder (6080, 6090, 6603, 6603x) had no "direction bit" so there was no memory in the decoder of the direction of travel.
I don't know how the CS2 shuttle system works, but maybe it needs this "direction bit".
Offline Crocodile
#3 Posted : 11 November 2014 15:16:08(UTC)
Crocodile
Thanks so much. I didn't know. Explains everything.
Edited by user 14 November 2014 15:31:07(UTC)  | Reason: Not specified
This page was generated in 0.330 seconds.
