Offline Ausipeet
#1 Posted : 10 November 2014 01:30:14(UTC)
Ausipeet
Hello all Me again,
am looking to get some advice as to what to do with this unit please, Purchased it from a club member some months ago and ever
since this unit will not run properly on either my layout or on the clubs layout, some times it will run for a short time and other times
it will not run at all. it has been looked at by several members over this time and we have discovered that it is shorting out in the housing where
the reversing unit is mounted to the chassis.
( i will attempt to add a drawing of this unit with part numbers listed and then try to explain the problem)
The area of concern is where part 38 , the Swivel arm is connected to the chassis.
is there any way that this can be fixed i am at a loss as to what to do here have cleaned the area have tried insulating the screw but nothing seems to work.
Hope some one can steer me in the right direction
thank you Peter
Offline Ausipeet
#2 Posted : 11 November 2014 02:41:09(UTC)
Ausipeet
pROBLEM SOLVED WITH HELP FROM PEOPLE ON THE fACEBOOK SITE.
#3 Posted : 11 November 2014 09:17:30(UTC)
Hi Peter,
For those of us not on facebook, can you give us an idea of how you solved the problem?
Thanks!
#4 Posted : 11 November 2014 14:41:09(UTC)
Hi Peter,
Thanks!
Don't know what happened for sure, but I'll venture to say that the little arm carrying the inversion relay must be left "floating" instead of tightened to the articulated chassis.
Problemn much easier to solve when converted to digital!! Cool BigGrin
Offline DV
#5 Posted : 12 November 2014 03:55:05(UTC)
DV
Hi Peter,
Thanks!
Just in case Peter forgets, here is the facebook trail
Bob Worthington :-
The screw mounting the reversing relay is plastic, and there is a plastic washer between the black metal mount piece and the relay. This means the relay is insulated from the chassis. Also ensure the electronics are not shorting to the chassis. Like you I found the black mount piece to be somewhat loose at its attachment to the chassis and cannot be tightened.
Peter:-
thank you for this Bob, having just looked at my beats again i know that the screw holding the reversing unit to the Chassis is metalic so therein may lay the problem me thinks?
Peter :-
Looks like i have it solved thank you all for your input, ended up using a piece of insulation with a small hole and now it seems to run like a dream on my layout, will see how it goes on the clubs layout this week sometime. again thank you all for the suggestions.
Peter's answer :-
Dont want to convert any of my loco's to digital LOL only want to run analog here
Answer back from other facebooker :-
Digital engines can run on analog layout.
Peter's answer:-
yes i know but not recomended to use the old style blue transformers, which is what i have , can not afford to buy the later grey models
I know Peter won't mind me answering on his behalf as we are good club buddiesBigGrin ThumpUp........right PeteConfused Confused ThumpUp ThumpUp
Dusan V
thanks 2 users liked this useful post by DV
#6 Posted : 13 November 2014 09:11:57(UTC)
Thanks Dusan.
I have a Br85 myself so I was interested in case it happens to me. It turns out it's unlikely as mine is digital, but it doesn't hurt to have more information.
#7 Posted : 13 November 2014 10:21:16(UTC)
Originally Posted by: DV Go to Quoted Post
Peter's answer :-
Peter's answer:-
Fine, that's totally reasonable and understandable!
As usual, I was simply sharing what I learned many years ago as a Märklin repair man when I saw multiple 3309's coming my way , all with the same problem.
The problem will occur again and again (e.g. when you have to change brushes or the fragile low voltage bulbs) as the articulated chassis design is rather finnicky
My suggestion was only offered as a way to solve the difficulty once and for all.
Of course I probably should have guessed there were only old blue transformers involved!Confused
Dumb me!Blink )
Offline DV
#8 Posted : 13 November 2014 22:17:05(UTC)
DV
Dumb me!Blink )
NO, not dumb you, you just don't understand Pete's outlook on digitalBigGrin LOL Blink BigGrin Blink LOL and being members of the same club for quite a while, I sometimes have problems understanding his outlook on didgitalBlink Confused Blink Confused BigGrin BigGrin BigGrin BigGrin
I totally agree with your statementsThumpUp ThumpUp ThumpUp
Good thing Pete can take jokes really wellThumpUp ThumpUp ThumpUp ThumpUp
Oh well, we'll have something to discuss at tonight's meetingRollEyes ThumpUp Smile BigGrin LOL LOL LOL
Dusan V
Offline Ausipeet
#9 Posted : 14 November 2014 22:56:02(UTC)
Ausipeet
My thanks go to Dusan for reposting the solution i received from usernet facebook users and i apologise for not posting the result here after receiving it.
And yes he had a go at me last night
This page was generated in 0.500 seconds.
