Offline PMPeter
#1 Posted : 07 November 2014 06:00:19(UTC)
PMPeter
As suggested in the Viessmann Decoder thread I am attaching a sketch of my current connection and my understanding of a "common ground". I can already hear the shudders of me using a blue transformer for the catenary (no sliders on the locos), but that is only temporary until I have the associated locos converted to digital and then the 6021 will take over or the catenary will no longer be live.
Other than that is the concept regarding my common ground bus correct?
Power
#2 Posted : 07 November 2014 07:33:15(UTC)
Hi, Peter,
No problem with your concept: it's important to keep the 60065 insulated from the common ground because it feeds a "modern" controller (CS2 here) which is connected to the common ground.
No problem having a common ground with 6021 and its transformer.
Offline PMPeter
#3 Posted : 07 November 2014 16:56:00(UTC)
PMPeter
Thanks Tom.
As I said in the other thread I never even considered connecting the 60065 output side to the ground bus. I'm not even sure how you could do that without modifying the supplied cable. It was just incorrect choice of my wording that caused the confusion and that teaches me not to respond to a thread during the work day.
I was wondering about joining the 2 Browns on the 6001, but it seems to already be an internal connection. So if I understand correctly from your response the Brown output of the 6021 can also be connected to the Common Ground Bus.
#4 Posted : 07 November 2014 21:13:22(UTC)
Peter,
The "Intent" of your schematic is unclear because you do not represent the internal links.
I believe your intent is to represent a common from the Controllers to the Track rail (not controller through transformer to rail)
By showing the connection to the 6001 you are implying a connection through to the 6021 but this implication would be lost on some.
I would suggest that the link from the Common Bus to the 6001 be removed and be replaced with a link from the 6021 Brown to the common ground.
By all means draw a dotted internal link within the 6021 between the 2 Browns.
I would further suggest you clarify the "load" and electrical return path for your lighting circuit.
IF you are wishing to represent light that use the track as return (M-Track turnout lanterns and buffer lights) then yes another common link is required
Offline PMPeter
#5 Posted : 07 November 2014 22:25:42(UTC)
PMPeter
Peter,
The intent is that I have 4 buses running around my layout, 3 of which are power sources and one of which is a common ground. All the red track leads come from the red Track Power Bus, all the yellow lighting leads come from the green Lighting bus, all the catenary feeder masts connect to the Catenary Power bus, and all the brown wire returns for everything go back to the Ground bus. Yes I can show the brown from the 6021 going to the Ground bus as well, but it is currently not connected to anything other than the 6001.
The whole discussion stemmed from the other thread regarding what brown wires can be connected together without causing damage to the CS2.
#6 Posted : 07 November 2014 22:27:53(UTC)
The only other comment that I would make in regards to using the older blue transformers, is that you make sure you get the brown and yellow in phase with the rest of the system. With the US style of 2 pin mains plugs which can be plugged into the mains either way around, this means that the yellow and brown connections could be reversed in polarity, and you end up with 20v AC feeding into the brown connection. Any other blue transformer in the system could end up with mains voltage on its unplugged mains plug due to 'back transformering'. This is the reason why Marklin recommend you use the later white/grey transformers as they have inbuilt protection against 'back transformering'.
I've attached some pages from the Eckert's Electrical Wiring for Marklin book, which shows how to get blue transformers in phase / correct polarity. The book specifically refers to analog running, but would also apply if you were using blue transformers to power accessories on an otherwise digital layout.
This procedure may not be so applicable in countries with 230/240v AC mains, as the mains plugs in those countries can only be plugged into the mains one way. However, it has been commented on the forum before that mistakes can be made at the factory in the wiring when the transformer is manufactured that it doesn't hurt to check everything to make sure!
The full version of the Eckert book can be found at http://lctm.atarrabi.org...Marklinwiringbooklet.pdf (I think they may have got it off me in the first place!)
Bigdaddynz attached the following image(s):
#7 Posted : 07 November 2014 22:47:16(UTC)
You only have to pay attention to polarity if you use two or more transformers to drive analogue trains and have trains passing from one transformer to another.
You'll get big sparks on the transition when polarity does not match.
Same for blue transformers, grey transformers, gray-and-black transformers, ...
Offline PMPeter
#8 Posted : 07 November 2014 23:01:15(UTC)
PMPeter
Understood and I am only using one blue transformer until I have my electric engines converted to digital. Then it disappears from my layout.
Common ground (Digital)
by Pfalzbahn 11/07/2020 16:18:00(UTC)
Marklin devices and "common ground" in rails and/or sharing power (Digital)
by fje 04/02/2015 18:18:37(UTC)
Common Ground (Digital)
by Mike M 18/12/2013 22:04:00(UTC)
Common ground k83 (Digital)
by Gregor 12/02/2009 14:07:20(UTC)
ECOS and common ground (Digital)
by Hobbit 05/11/2008 04:51:56(UTC)
eCOS and Common Ground (Digital)
by xxup 31/12/2007 13:24:34(UTC)
Common Ground? (Digital)
by elsleuth 18/12/2007 03:10:04(UTC)
This page was generated in 0.371 seconds.
