Offline Imagine
#1 Posted : 01 November 2014 15:45:32(UTC)
Imagine
Is it possible to convert the SK 800 to digital?
Imagine attached the following image(s):
#2 Posted : 02 November 2014 23:27:16(UTC)
The SK800 is not on Marklin's list of locos that can be converted to digital. I assume that the SK800 has a LFCM, but I don't know if the LFCM kit for digital operation will fit the SK800. You might be able to use a decoder such as the TD101 (www.trenesdigitales.com.ar/en/decoders/10-td101.html) which can drive an AC motor without having to convert the motor with a permanent magnet.
I've never ever heard of anyone converting a SK800 to digital, and I certainly won't be converting mine!
Offline TroyYang
#3 Posted : 03 November 2014 00:43:06(UTC)
TroyYang
Using the old c80 6080 chip might work.
Troy
San Francisco, USA
Offline kweekalot
#4 Posted : 03 November 2014 08:04:05(UTC)
kweekalot
Topic moved from Steam to the Collector's Corner.
#5 Posted : 03 November 2014 10:19:26(UTC)
Hi Marco, I think this topic may get more replies in the "digital" section. Certainly there will be few true collectors of old Marklin who would have experience of converting their locos to digital.
To keep as much of this loco as possible in original condition I would use one of the decoder types that keeps the AC motor. The 6080 decoder should do, or the 66032 newer Delta decoder, which has the possibility of an extra function.
Needless to say I would keep safe any parts that are taken out, such as the reversing unit and original wiring, to be re-instated in the loco if desired in the future.
#6 Posted : 03 November 2014 10:35:35(UTC)
My thoughts exactly, so topic is moved to the Digital section.
#7 Posted : 03 November 2014 12:58:16(UTC)
I think that a Marklin collector would never converted this locomotive to digital.
Offline kweekalot
#8 Posted : 03 November 2014 15:24:37(UTC)
kweekalot
I won't convert it either, but some do ...
Offline biedmatt
#9 Posted : 03 November 2014 15:40:22(UTC)
biedmatt
Convert it.
If it just sits on a shelf, or worse, is left forgotten in a box because your layout is now digital, then why even keep it? Don't say investment, you'll do better with the money in the stock market.
Use a 6080 so you can keep the original motor and do not cut, chop or butcher anything for the conversion. Save the parts so you can put it back in the future.
Matt
Era 3
Marklin SK 800s in various colors (Collector's Corner general)
by CCS800KrokHunter3 01/10/2019 15:03:54(UTC)
Marklin SK 800 / RS 800 set from 1945 (Collector's Corner general)
by CCS800KrokHunter3 29/09/2017 03:12:37(UTC)
Marklin SK 800 K Finally found on ebay! (Collector's Corner general)
by CCS800KrokHunter3 25/02/2008 05:51:16(UTC)
This page was generated in 0.591 seconds.
