Offline morsing
#1 Posted : 27 October 2014 11:24:24(UTC)
morsing
I have a kit with an MS2 and a basic 36VA power supply.
I have 2 trains, currently not with lit coaches but that will probably come, 2 electric points (no lantern, but might get that later) and 3 uncouplers.
How close am I to maxing out my 36VA power supply?
Also, I can't find any detailed information about how boosters connect.
Can boosters be used with just the MS2 and 36VA supply?
Edited by user 28 October 2014 11:51:32(UTC)  | Reason: Speeling
Marklin C-track + CS3+
Offline Renato
#2 Posted : 27 October 2014 22:41:51(UTC)
Renato
AFAIK it is not possible to connect boosters to MS2 (or MS1): the CU 6021 and the newer Control Stations have the hardware (external sockets) for the booster connection.
Renato
#3 Posted : 27 October 2014 23:43:18(UTC)
Originally Posted by: morsing Go to Quoted Post
Can boosters be user with just the MS2 and 36VA supply?
The Marklin 60129 "Connect6017" might be one option.
It has been discontinued, however I note LokShop has yet to run-out.
This is a parasitic device that takes the signal from the track - rather than the controller directly
Similar workarounds use the DeltaControl in a similar manner (But these do not offer booster connection)
Other homemade variants are available
Your mileage may vary if you want MM, DCC, MFX all together......
DCC and MFX will , only work in one direction (as designed, although you will find backfeed circuits for mFX on this forum)
Offline madhu.gn.71
#4 Posted : 28 October 2014 08:20:22(UTC)
madhu.gn.71
India
Sorry for squeezing in my query here. How many locos can one MS2 with power supply support (without boosters)?
I know that the power supply that comes with Marklin My World start up packages can manage a maximum of upto 2 locos
Madhu
Offline madhu.gn.71
#5 Posted : 28 October 2014 08:31:12(UTC)
madhu.gn.71
India
I Googled and got the answer for this query of mine
https://www.marklin-user...IX-66950.aspx#post266577
Thanks to Tom for this excellent review of MS2
Madhu
This page was generated in 0.484 seconds.
