marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
Reviews
Loco Reviews
Märklin BR64...39644...it´s back!
2 Pages
1
2
Go to Page...
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
Posted :
22 October 2014 18:51:50(UTC)
Retweet
I think 39644 carry 3-poles?
Yes it does.
User Profile
View All Posts by User
View Thanks
Posted :
22 October 2014 19:04:00(UTC)
Retweet
Originally Posted by: Purellum
Even if is a kind of provocation.
There is no reason to write "even if",because it seems non-trusting side from someone.
I see like that.
You should not see it like that, because it is not correct. You feel provoked, because you don't understand the meaning of what is written in English.
Please look at this:
http://www.learn-english...even_though-even_if.html
If you did read Per...
"Even if" used in a supposition or hypothesis.
So there is no reason to suppose by write "even if"...
User Profile
View Thanks
Posted :
22 October 2014 20:38:40(UTC)
Retweet
Anders, you need to take other peoples's word for it. It is a common English expression, and is not in any way an insult.
Please get over it!
3 users liked this useful post by RayF
Janne75
User Profile
View Thanks
Posted :
22 October 2014 20:46:38(UTC)
Retweet
Please get over it!
It present an insult anyway.
User Profile
View Thanks
Posted :
22 October 2014 20:48:56(UTC)
Retweet
By the way...i did tested my new locomotiv and it works without default(s).
2 users liked this useful post by Goofy
franciscohg
MikeR
User Profile
View Thanks
Posted :
22 October 2014 21:10:39(UTC)
Retweet
It present an insult anyway. Flapper
The only one insulting others in this forum is you.
Please stop doing it.
3 users liked this useful post by Purellum
Janne75
User Profile
View Thanks
PMPeter
#57
Posted :
22 October 2014 21:39:28(UTC)
Retweet
Please get over it!
Good grief. The wording "even if" as stated was absolutely correct in the English language. If you are hung up on the word "if" substitute it with "though" thus stating "even though" and you get the same meaning. An English speaking person would never consider the phrase "even if" insulting.
3 users liked this useful post by PMPeter
Janne75
User Profile
View Thanks
Posted :
22 October 2014 21:42:08(UTC)
Retweet
Agreed! Goofy, enough of this childish behaviour. No one is trying to insult you, yet you see fit to continue to cause disruption in the forum - which is resulting in numerous complaints regarding your behaviour. I and others are getting sick of it. Enough Already! This is your last warning!
WWW
BLOG
11 users liked this useful post by Bigdaddynz
PMPeter
Joseph Meiring
kweekalot
DV
sjlauritsen
NZMarklinist
Janne75
Torstein
User Profile
View Thanks
NZMarklinist
#59
Posted :
23 October 2014 10:35:05(UTC)
Retweet
Originally Posted by: NZMarklinist
Originally Posted by: stevend
The problem has been oil/lube getting into the motor. The brushes over time disintegrate, the resulting conductive brush muck ends up in the slots between the commutators, this causes the motor to short out its poles resulting in very slow running as best, and at worst destroying the decoder. This is a similar problem that occurs when people get oil on the 6090x motor brushes.
I've had to replace every motor on this model I've seen to date and sometimes twice replaced before I worked out what was occurring and hassled M for real a fix.
D
Pleased to hear Goofy has his Lok back and working well
As I haven't run my 39644 as yet I guess I should strip it, (need to to fit the smoke unit anyway), and remove the motor and check for excess lube
I wonder how many other can motored new models this could apply to
Thanks Dion for your contribution
I have four '64's, a fav of mine you could say
The SDS ones are a brilliant model
I should have mentioned that the difference with the '45s, and most of the other large Damphloks or Steamers, is that the motor is mounted to a gearbox and this may well be done by somebody more technically competent than the final assembly workers, and there is little or no oil or grease applied at this stage, as well as the fact that with the '45s at least, the shaft is pointing down hill away from the motor making migration of lubricant inside the motor can much less likely !
Glen
Auckland NZ
2 users liked this useful post by NZMarklinist
Janne75
MikeR
User Profile
View Thanks
digitaltrains
#60
Posted :
23 October 2014 11:32:39(UTC)
Retweet
That post was more than 6 months ago, and I believe we have thrashed the "3 pole motor" discussion to death now.
If you have this actual loco and want to post on the performance of your actual loco then do so, but please refrain from spreading this idle speculation....
Hello, RayF!
So, You did "trashed" this motor already?!....and what is your experiences regarding this motor? Are You satisfied with it giving hundreds of Euros for no-name motor? Are You generally satisfied with the model You have?
Thank You on your answer.
User Profile
View Thanks
Posted :
23 October 2014 14:56:48(UTC)
Retweet
Hello, RayF!
I haven't "trashed" anything. (???)
You can go back and read my answers, but if you prefer to continue this endless and pointless discussion, I'll state it again here.
The locos I have with 3 pole motors, among them the much maligned Br94, run as smooth as most other locos I have in my collection, which runs now to 128 locomotives and railcars.
The only observation I can make with some of these locos is that the slowest running speed is slightly higher than on some other locos, but it is still good enough to be classed as "walking pace", so I'm happy with the performance. Certainly I would consider this motor to be superior to the old
DCM motor which is noisy and rough.
Looking inside the body I find a motor which looks professionally put together. The design is compact, allowing the steam locos to have the motor totally hidden in the boiler.
The price, seeing as you mention hundreds of euros, is competetive,and in many cases cheaper than the equivalent Roco or Fleischmann locos, many of which have also 3 pole motors.
In all I am, to answer your question, perfectly satisfied with my models.
How about you? How many of these locos do you own? If none, have you tried out one of these perhaps on a friend's layout, or in a shop? Can you explain why you have such a poor regard for these motors?
6 users liked this useful post by RayF
Joseph Meiring
Hoffmann
Janne75
MikeR
User Profile
View Thanks
Posted :
24 October 2014 09:32:00(UTC)
Retweet
"Even if" used in as supposition and hypothesis.
Per did present it as posts,which is not my fault.
I did just verified what you and Per has done.
Sorry David...but there is no reason by writing "even if" to me by post.
Yours version by suppose about my model seems and are supposition.
Yours warning is not even closed to fair.
User Profile
View Thanks
Posted :
24 October 2014 09:56:51(UTC)
Retweet
Yes, and you're right Goofy and everyone else on the forum who has commented about this is wrong..................(somehow I don't think so!)
Given that complaints have been received by the Moderators about your behaviour, and that we have given you a number of warnings to stop (which you have ignored), I think we have been more than fair.
As I said, that was your last warning!
WWW
BLOG
9 users liked this useful post by Bigdaddynz
kweekalot
DV
PMPeter
Janne75
NZMarklinist
JKJ
User Profile
View Thanks
digitaltrains
#64
Posted :
06 November 2014 13:19:31(UTC)
Retweet
Hello, RayF!
Hello, RayF!
Sorry for delay but I was occupied with some other things...First of all, thank You on your answer regarding three pol motors!
As I said previously, I have none of these locomotives in my collection. However, I have a lot against it as I saw many other motors of similar construction which runs on DC or DCC with many defects and those motors are much better then this one, at least, the manufacturer is very well known! However, most of them are very good even excellent (few of them). In this case, I am not so sure...
My trains are "long runners" and they are running for thousands of kilometers per year in exact scale which means that 1km is equal to 11,5 meters. Every weekend or almost every weekend, my trains are running at least for 5 hours (constant run).
Someone said almost everything regarding these can type motors and what is happening to them during time (circle fire on collector and the end is near caused by the short circuit on collector's sectors by the brush dust!) and I saw how Roco's models are behaving after some time and I have some of them - loco won't start unless you push it by a hand or create your own impuls power so you can start it, motor overheating and such...
Did You notice that Marklin shorter its guarantee for the model from 5 years to 2, perhaps?! Well, it is the excellent sign of the quality of its engine.
To me, new models equiped with that motors looks like "Ferrari with Punto's" motor inside....and that is not good, not good at all...You (all of us) are paying to get "Ferrari" and not "Punto" for sure!
Marklin stated that "c-sinus and Faulhaber's" are "too expensive"....hmm...well, Marklin did not order 10 Faulhaber's for their models ever and that is the first thing! Second, they ordered thousands of them so the price for one is low and they could easally use them in all other models as well, but no, they want much bigger profit and that is not good for them in all cases.
As a Marklin collector, I am very disapointed that Marklin, actually, became "ordinary" manufacturer of the DC models which can run on Marklin tracks - nothing more nothing less. Yes, they look great outside, but the model, just, can not be used in a way that I am using it and that is the main reason why I started to collect Marklin long time ago - superior quality! And the model life time is shorten and they, just, do not last for longer period of time (this is speculation as I really do not know how long they can last, but, according to its construction, price of the new one, they just can not be high quality ones)...
I wonder why did not Marklin made a real presentation of their new "high efeciency" motor nor they engraved the company's name on it?!? Well, they did not engraved its company's name because it can ruin their reputation in a second...so they "hide" their reputation behind "no named" motor...
In the end, I want to say this: let us all hope that those motors can be used for longer period of time and after that, let me say - for at least 11 years, to change the motor with the new one. If this is the case, Marklin did the right thing!....but, I have serious doubts about this and I do really hope that I am wrong in this matter...
With best wishes and regards to You and all Marklin collectors and hope that those motors are fine,
Digitaltrains
1 user liked this useful post by digitaltrains
grnwtrs
User Profile
View Thanks
Posted :
06 November 2014 20:03:33(UTC)
Retweet
No, they didn't.
It was and is five years after date of production for MHI items. Insider models are MHI models.
It was and is two years after date of purchase for all Märklin items.
Normal wear (light bulbs, torn traction tyres, worn brushes, worn sliders) is not covered by the warranty.
a high level of quality
, the
, and
absolute precision
. You will see that
in all of our products
3 users liked this useful post by H0
franciscohg
Joseph Meiring
User Profile
View Thanks
Posted :
07 November 2014 09:04:04(UTC)
Retweet
Broken LED´s do cover warranty,since it´s not possible(?) to change byself to new.
User Profile
View Thanks
2 Pages
1
2
Go to Page...
Reviews
Loco Reviews
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
- Märklin Factory Layouts
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
YAF.NET © 2003-2024, Yet Another Forum.NET
This page was generated in 0.865 seconds.
