marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
General MRR
Why I dislike MFX and how we are not offered a functional alternative
3 Pages
1
2
3
Go to Page...
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
biedmatt
#101
Posted :
06 October 2014 12:44:30(UTC)
Retweet
I have replaced a lot of MTC21 decoders and have not had any problems getting them to work. Perhaps I have been lucky. As Tom states, there is more than one standard for the 21 pin connector. Edit: I do not know if Marklin uses more than one standard.
I did have trouble identifying which output was under which decoder function. Slider changeover relays (2 functions btw), power for sinus drives, interior lighting, all needed to be configured with trial and error until I bought the ESU decoder tester and could quickly identify output-function pairings. Marklin tries to put outputs under the same decoder function. Sinus drive power is usually F4, but this is not steadfast and true.
Matt
Era 3
User Profile
View All Posts by User
View Thanks
Posted :
06 October 2014 13:47:48(UTC)
Retweet
So, I guess the question being specifically asked is whether an ESU Loksound 4.0 decoder with 21 pin socket will work in the 21 pin mtc interface board that came with a mSD decoder that is fitted into a loco with a DCM motor (not in a later loco with a locked mSD decoder)?
The decoder will work - but items connected to AUX3 or AUX4 could be a problem.
@Matt: old mfx decoders came from ESU and locos had 21MTC boards compatible with NEM 660. Newer locos come with Märklin mfx decoders and may require AUX3 or AUX4 to be amplified and ESU decoders will not work.
Some locos do not use AUX3 or AUX4 and both types of decoders can be used.
a high level of quality
, the
, and
absolute precision
. You will see that
in all of our products
3 users liked this useful post by H0
biedmatt
NZMarklinist
User Profile
View Thanks
Posted :
06 October 2014 22:08:40(UTC)
Retweet
Thanks Tom. That particular loco (BR53) as converted has smoke on AUX1 and the Condenser Fans on AUX2, nothing on AUX3 or AUX4.
WWW
BLOG
User Profile
View Thanks
Posted :
11 October 2014 09:12:45(UTC)
Retweet
Yesterday night I attended a club meeting.
We had problems with mfx registration - using Märklin locos and a Märklin Central Station.
After some trial and error we found out that we just had to lift the centre rail slider of the Märklin 43204/43252 coach set off the track to get locos to register.
Each time we put new locos on the track, we just put a sheet of paper under the centre rail slider of the 43252 and the locos would register.
It's known for a long time that interior lights with a buffering capacitor can disturb mfx feedback. Bad sign that factory-installed interior lights also function as an mfx feedback filter.
Running locos can also disturb mfx feedback. At another club meeting where we were using the MS2 we had to stop all trains because running trains would prevent the registration of new locos.
, the
, and
absolute precision
. You will see that
biedmatt
Danlake
User Profile
View Thanks
Posted :
11 October 2014 09:18:22(UTC)
Retweet
An simple question...
Do Märklin have buffering capacitor too in the lighting sets?
User Profile
View Thanks
Posted :
11 October 2014 13:17:02(UTC)
Retweet
That's why Märklin say that nothing else should be on the track when registering a loco. I guess we can't blame the technology if we don't follow the given instructions properly!
I have 2 Railcom locos - my ESU BR215 and my KM1 BR01 Gauge 1 loco. The KM1 registers fine (and within a few seconds) on my Ecos, even though there are coaches on the track.
WWW
BLOG
User Profile
View Thanks
Posted :
11 October 2014 13:18:16(UTC)
Retweet
They don't have a capacitor in my G1 coaches......
WWW
BLOG
User Profile
View Thanks
Posted :
11 October 2014 13:30:01(UTC)
Retweet
Where do they write that?
Nowadays we want technology that works without reading manuals.
Here's what I found in the Central Station manual:
Place locomotives to be registered one after the other on the
layout. If several locomotives to be registered are on the track
at the same time, the complete process can take considerably
longer to complete.
They don't write that only one loco should be on the layout. Just add one loco and wait until it finishes registration to save time.
mfx+ also relies on mfx feedback.
Would be very cool if the Spielewelt cab imitation only worked with a single loco on the track, wouldn't it?
Maybe Spielewelt won't work if you have the snoring sleeping car activated on the layout.
, the
, and
absolute precision
. You will see that
User Profile
View Thanks
Posted :
11 October 2014 16:15:46(UTC)
Retweet
I´m not really sure,if Railcom with feedback do have disturb too,when there is buffering capacitor in the lighting sets.
User Profile
View Thanks
Posted :
11 October 2014 17:21:25(UTC)
Retweet
RailCom feedback works completely different. Disturbance from buffering capacitors is IMHO very unlikely.
RailCom is optional and can be disabled in the decoder. If RailCom fails, the loco can still be registered manually using DCC.
, the
, and
absolute precision
. You will see that
User Profile
View Thanks
Posted :
14 October 2014 02:04:52(UTC)
Retweet
longer to complete.
You're splitting hairs there a bit Tom! Even if it isn't written down formally, it has always been accepted convention that you will get faster and more reliable registration if only 1 mfx locomotive is on the track when registering.
However, I knew I had seen it written down somewhere and indeed I have. See page 17 in the Ecos 2 manual (even if it is ESU saying it and not Märklin).
"11.2.1. Entering M4 locomotives
We recommend placing new locomotives on the layout one at
a time. If there are several new locomotives on the layout then
the registration process may be unnecessarily delayed."
WWW
BLOG
User Profile
View Thanks
Posted :
14 October 2014 02:19:44(UTC)
Retweet
I agree with BigDaddyNZ - I have see it written somewhere too.. I think that one of the English edition Insider or Marklin magazines tells you that only one new mFx loco should be on the track at one time..
Australia flag by
abFlags
.com
1 user liked this useful post by xxup
User Profile
View Thanks
biedmatt
#113
Posted :
14 October 2014 05:37:31(UTC)
Retweet
I think Tom is saying that you must have only one new loko on the track. That is very different from only one loko on the track during registration. If it is the latter, then you must remove all lokos except the new one from the track. Very impractical and what affect would that have on re-registration? Would you then loose sync with prior registrations and end up with the other lokos re-registering when placed on the track? All this strange and abnormal operation is exactly why MFX is such a mess. Do this, but do it exactly like this, in this prescribed order or you will end up with your lokos having to re-register. Why must we have so many conditions on a system sold as plug and play?
Matt
Era 3
1 user liked this useful post by biedmatt
User Profile
View Thanks
Posted :
14 October 2014 07:57:26(UTC)
Retweet
We had three locos on the track - and one coach set with interior lights. One loco and the coach set were already registered. The mfx sign was off and no registration took place for the two unregistered locos until we put a sheet of paper under the centre rail slider of the sleeping coach.
Later one of the locos was taken off the track and another loco was added. The mfx sign was off and no registration took place until we put a sheet of paper under the centre rail slider of the sleeping coach.
You call it "splitting hairs". We followed recommendations and still it did not work as intended.
, the
, and
absolute precision
. You will see that
User Profile
View Thanks
Posted :
14 October 2014 10:35:30(UTC)
Retweet
I often have a rolling road or some pieces of track plugged into the programming track output on the Ecos / CS2. That way it is easy to unplug the layout, leaving only the programming track connected.
You're taking me out of context there - the splitting hairs comment referred to you questioning whether there were written instructions or not, to have only 1 loco on track when registering a mfx loco. Nothing to do with what you had to do at your club to get your locos registered.
WWW
BLOG
User Profile
View Thanks
MalinAC
#116
Posted :
14 October 2014 12:41:23(UTC)
Retweet
After seeing all the problems on this post about MFX and all the other new fangled digital gadets I know I was right to stay Analoque. No trouble and everything works as it should - most of the time. Stay happy and positive Eddie
2 users liked this useful post by MalinAC
usbeauty
kweekalot
User Profile
View Thanks
Deborail
#117
Posted :
15 October 2014 08:11:23(UTC)
Retweet
Last night I received a new loco, the French Crocodile, BB 12000 series, Trix 22336, and this comes with an MFX decoder. I must say that there is no need to do the programming with this decoder. It auto-programs itself and its ready to run once it is placed even on the main track. I used to like the procedure of opening up the loco and installing the decoder and then putting the loco on the programming track to program it.
I don't know if I can say that I dislike mfx, I feel ambivalent.
George
Given enough time, tasks manage themselves.
3 users liked this useful post by Deborail
MikeR
Janne75
User Profile
View Thanks
Posted :
15 October 2014 11:47:32(UTC)
Retweet
Eddie, are you sure you're happy with analogue electric operation? Why not stick to tried and tested clockwork? No problem with the technology there!
User Profile
View Thanks
perz
#119
Posted :
15 October 2014 23:00:03(UTC)
Retweet
Interior lights with big capacitors are very likely to kill the mfx feedback signal. The feedback is achieved by varying the current consumption of the decoder. This variation is then converted to a signal voltage in a signal transformer in the controller (or in the mfx capable boosters). A big capacitor in the circuit will even out the current variations so that they get too weak to be picked up by the controller.
This is the same electrical principle as in the Digitrax system.
The Railcom works differently. Here the feedback is a voltage driven by stored energy in the decoder during short periods of "dead" track voltage. This can of course also be disturbed by other things on the track, but since the principle is fundamentally different from mfx feedback it can be completely different things that disturb it.
By the way, the mfx protocol itself can very well be operated without feedback, by using manual registration. The fact that this option is not offered in the controllers seems to be only a marketing decision.
WWW
10 users liked this useful post by perz
Janne75
biedmatt
NZMarklinist
MikeR
Danlake
mjrallare
User Profile
View Thanks
Deborail
#120
Posted :
16 October 2014 07:07:30(UTC)
Retweet
Hello Perz, your comments about the various electronic phenomena occuring are very interesting. I have a DSO (Digital Oscilloscope) and a Wavefrom Generator. I wonder if these two could be put to use to observe these phenomena. Unfortunately my knowledge in electronics is limited but I am still very interested.
George
User Profile
View Thanks
perz
#121
Posted :
16 October 2014 23:32:03(UTC)
Retweet
With a digital oscilloscope you can observe the signal behaviour and also see different disturbances. Measuring on mfx feedback is a bit tricky since it is small current variations on top of a large current, which is also varying, but slower. An oscilloscope is however not really sufficient if you want to analyze the data patterns on the signals going back and forth. Then you need some kind of protocol spy tool, with capability to take longer recordings than a normal digital oscilloscope can. I built such a spy tool for my investigations but it only supports analysis of the forward signalling so far.
WWW
5 users liked this useful post by perz
Danlake
NZMarklinist
mjrallare
User Profile
View Thanks
leahcim
#122
Posted :
17 October 2014 05:09:33(UTC)
Retweet
Views messages in topic : 40
Hi Perz,
I know a lot of DSO's are limited in memory depth which can make it difficult to spy on some signals.
But the oscilloscope can handle the voltages used in marklin digital better than some other logic devices.
What kind of length of time do you think is necesary to monitor the mfx signal?
Having only just got the grasp of the motorola protocol I haven't studied any information on mfx. All that I've found so far is
in German.
As I only have an old analogue scope I bought one of these
cheap logic analyzers
off ebay.
So far I have been able to look at the signals generated by my delta controller so at under $10 I think it was a
good buy.
Anyone buying one of these cheap analyzers does need to understand about using a diode and voltage divider
to keep the voltages between 0 and 5v tolerance of this device.
The
software
is free and I think it's great value. I'm not sure when I will have access to an mfx controller to see
how it works with that.
michael
1 user liked this useful post by leahcim
User Profile
View Thanks
perz
#123
Posted :
17 October 2014 19:34:35(UTC)
Retweet
Originally Posted by: leahcim
Hi Perz,
To really get a feeling for what is going on we are talking about several minutes. Of course you can see some interesting things with much shorter traces too, but you will only get fragments then.
WWW
2 users liked this useful post by perz
mjrallare
User Profile
View Thanks
Deborail
#124
Posted :
19 October 2014 07:56:51(UTC)
Retweet
I will try this when my scope and gen arrive...
George
User Profile
View Thanks
3 Pages
1
2
3
Go to Page...
General topics
General MRR
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
- Märklin Factory Layouts
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
YAF.NET © 2003-2024, Yet Another Forum.NET
This page was generated in 0.952 seconds.
