Offline Simon
#1 Posted : 19 September 2014 14:42:05(UTC)
Simon
I have several locomotives with sound. For some of them I can find which loudspeaker it has inside. But for some locomotives there are no exploded views with spare parts.
Does anyone know if there is a list with the specifications of (all) the different loudspeakers Märklin is using (ohm and watt).
Thanks in advance.
Offline waorb
#2 Posted : 19 September 2014 15:34:44(UTC)
waorb
Brazil
Hello Simon!
I got the list below... seems a lot of models (maybe someone are the same with diferent numbers)... unfortunately no specifications, but it's a start to know how much loudspeakers Märklin have.
IMHO, it's better to search in the booklet of each loco do you have, and search specifically for them.
Walter
Zubehör-Set Lautspr.,Haltebüg (Märklin E184136 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E180289 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E180357 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E180622 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E180680 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E180723 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E180731 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E183895 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E184591 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E186364 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E187268 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E187669 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E188161 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E189233 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E192421 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E192515 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E192516 ) [Mehr...]
Zubehör-Set Lautsprecher (Märklin E193286 ) [Mehr...]
Zubehör-Set Lautsprecher (Trix E191563 ) [Mehr...]
Zubehör-Set Lautsprecher (Trix E192490 ) [Mehr...]
Zubehör-Set Lautsprecher kpl. (Märklin E182414 ) [Mehr...]
Zubehör-Set Lautsprecher kpl. (Märklin E186183 ) [Mehr...]
Zubehör-Set Lautsprecher m. R (Märklin E183288 ) [Mehr...]
Zubehör-Set Lautsprecher u. W (Märklin E188302 ) [Mehr...]
From here:
http://www.spielzeug-paradies.de/products_index.php?y42_idx=z
Off-topic: Nice city do you live. I got an opportunity to be there in the late 1991. ThumpUp
Offline Simon
#3 Posted : 20 September 2014 09:56:02(UTC)
Simon
Hello Walter,
Thanks for your list. The reason I'd like an overview of the specifications is the large difference in prices.
For example, a loudspeaker on the site you listed costs, € 15. I bought 2 loudspeakers at Marklin in the Netherlands for € 6 each. In the electronicshop a loudspeaker (with almost the same specifications) cost less then € 4.
I was able to check the specifications because on one loudspeaker the specifications was printed. But on most of the others there was no printing on it.
And to make it easy, a lot (all?) of the numbers in the exploded view in the booklet, has been converter to a new number serie.
PS never been to your country, but it is on my to do list.
Offline waorb
#4 Posted : 22 September 2014 16:57:23(UTC)
waorb
Brazil
Yes, not all parts are fully specified...
I got a Lok in the last trip to Germany, and some kind of 'base plate' of the motor is described in the booklet, but don't have any number... how to know? Also don't know...
And also yes, loudspeakers in the market seems to be less expensive...
Walter
This page was generated in 0.357 seconds.
