Offline Dutchman
#1 Posted : 19 November 2009 20:25:24(UTC)
Dutchman
Dear forumer!
And there he is:
Just arrived in the Netherlands!
With the 'new' own(?) Märklindecoder inside...
With friendly greetings from the Netherlands,
Dutchman
Offline Armando
#2 Posted : 19 November 2009 20:52:20(UTC)
Armando
Congratulations on your purchase. Any interior details in the cabins?
Armando García
Offline Dutchman
#3 Posted : 19 November 2009 21:23:24(UTC)
Dutchman
Dear Armando,
[size=1" face="Verdana" id="quote]quote:Originally posted by Armando
<br />Congratulations on your purchase. Any interior details in the cabins?
No, there isn't in this new eloc an interior in the cabines, even as in the older types (DB Baureihe 194).
About the the decoder, it is not an ESU-Lopi V.3 but has the Märklin numbre:149 044
When using the Central Unit 6021 it is possible to write in CV75 another adress and then the functions F5-F8 are reachable too!
But when the elok is stopping in a currentless part of your rails (as for a red signal!) then the loc is starting <u>abruptly</u> as the signal is going on the color green.
It is <u>not possible to write in CV73</u> the value 03 or 07 (starting on speed 0 and accelerating to the former speed!)
[:(] as it was with the former MFX-decoders...
From wich producer this new decoders are comming is till this moment unknown...
With greetings from the Netherlands,
Dutchman
Offline Rinus
#4 Posted : 19 November 2009 21:43:56(UTC)
Rinus
Does it have full sound?
Never knew the Rh1020 had operated in the Vasoulek desigh.
Offline rugauger
#5 Posted : 21 November 2009 01:53:09(UTC)
rugauger
I don't know - those sandwiched layers of PCBs held together with double-sided foam pads just don't look right to me...
Richard
#6 Posted : 21 November 2009 02:24:18(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by rugauger
<br />I don't know - those sandwiched layers of PCBs held together with double-sided foam pads just don't look right to me...
Maybe it is a McDonald "Big Whoppa" decoder biggrin.
Offline kskato
#7 Posted : 28 November 2009 04:28:57(UTC)
kskato
Looks 'kinda like' its from the Bachmann 21-pin decoder maker.
(I don't know how to insert pics )
Link
http://www.ehattons.com/....aspx?searchfield=36-554
#8 Posted : 28 November 2009 10:54:09(UTC)
Here is a ÖBB Rh 1020 in a Valousek design
Offline Rinus
#9 Posted : 28 November 2009 16:29:32(UTC)
Rinus
I prefer it in jaffa design!
#10 Posted : 29 November 2009 21:31:14(UTC)
Nice pictures.
I see the model don't have red headlight.
Offline Rinus
#11 Posted : 01 December 2009 20:16:07(UTC)
Rinus
There are quite some differences with the prototype in the roof section, fronts and frontwindows as well.
But after all the M* 1/87 model is around for quite some time now. One can't expect a 40 year model to be up to date in level of detailing. There are other far more prototypical models of this fantastic train.
Just compare:
#12 Posted : 02 December 2009 02:19:54(UTC)
Don't know what you've seen; sure it does. wink
Lutz,
Are the working red marker lights above the headlights or are the integrated with the headlights.
The red marker lights are clearly dummy fixtures.
regards.,
Handle this question with care otherwise it could blow up in your face biggrin
regards.,
#13 Posted : 03 December 2009 06:15:12(UTC)
<br />Couldn't care less; light functions including red rear lights work as published. If one doesn't like what s/he gets with this model from Märklin simply change it.
PS: The mentioned Bachmann decoder has nothing to do with the sound pcb in this model.
I'll refrain from asking you questions in future.
regards.,
Offline contrans
#14 Posted : 03 December 2009 10:55:58(UTC)
contrans
[size=1" face="Verdana" id="quote]quote:Originally posted by river6109
regards.,
John,
Hemmerich posts sometimes show the same feature as the red light of this loco: bullsh-t doesn't leave the hole that is is primarily intended to be used.
biggrin
contrans
Offline Oliver SBB-CFF-FFS
#15 Posted : 19 September 2014 11:40:34(UTC)
Oliver SBB-CFF-FFS
I am reviving this thread since I would like to know (in reference to post #3, regarding CV75), what are the additional functions? More sounds? As I understand it this model only has a horn sound. Are there hidden (versteckte) sounds on this model too? Google has not yielded me any results.
Thankful for any input as the loco will soon join the fleet. Smile
SBB Era IV - VI
#16 Posted : 19 September 2014 16:26:15(UTC)
I don't have this loco, but it seems lights are control by F6 and F8 as usual - with a total of 5 functions.
People with access to a Central Station (60212 through 60215) can change the function mapping to have all five functions on F0 through F4.
All mfx decoders support a shunting mode which is normally not mapped to any function with Märklin locos. You can add a function key for shunting mode if you want to.
Owners of a CU 6021 can activate the second address to get all 5 functions using two addresses.
This page was generated in 0.958 seconds.
