Offline Moritz-BR365
#1 Posted : 09 September 2014 10:23:33(UTC)
Moritz-BR365
Here are some comments and pictures of the VT 75.9 (37705):
Here, You can see the gear box (brass gears!) and 5-pole miniature motor:
Mount RTS current-carrying clutch
The trailer car has only on one side a coupler pocket prepared for the current-carrying clutch. But the circuit board is prepared. Therefore, all You have to do is to insert the contact spring.
First, You have to release two screws from the bottom. Then, You can release the case. Next the two small plastic covers must be removed. Finally, there is one screw on the board to remove.
Now You can insert the contact spring and assemble everything:
The motor coach
The same must be done for the motor coach, but it is much more difficult. That's why I didn't have done the final step: To remove the circuit board and insert the contact spring. It was to risky for me!
Märklin 37705 - VT 75.9 - coupling with RTS short coupler and decoupling rail
thanks 2 users liked this useful post by Moritz-BR365
This page was generated in 0.205 seconds.
