Offline Emil
#1 Posted : 06 September 2014 22:45:37(UTC)
Emil
I really like the dutch railways and I've always wondered why electric locos in the Netherlands almost everytime they set off, use two pantographs.
Then mostly after about 100 metres the front panto is lowered.
On the NS 1200 series I read somewhere that the use of two pantos had to do with avoiding overstressing the system supplying power to the traction motors up to 30 km/h. On these locos its a very intricate system reminicent of the "knallfrosch" system of the DB Br 141.
But the practice of using two pantos is still used, even on modern locos without the special requirements of the 1200 series. I've seen it used on locos like the Traxx Br 186. And also frequently on the series 1600 and 1700.
Anyone know why?
Best Regards!
Emil
Edited by user 07 September 2014 13:52:05(UTC)  | Reason: Knallfrosch baureihe
#2 Posted : 06 September 2014 23:18:58(UTC)
Voltage in the Netherlands is only 10% of the voltage in Germany (1,500 V in the Netherlands, 15,000 V in Germany).
German trains can draw up to 600 A, even more on some new lines. Locos in the Netherlands have to draw 6000 A to get the same power (but I don't know how many amps they really draw).
Pantographs in Germany have two wipers, those in the Netherlands have four wipers each. With two pantographs raised, the power flows through eight wipers.
BTW: The Knallfrosch is the BR 141.
Offline Emil
#3 Posted : 07 September 2014 08:22:18(UTC)
Emil
Ah, OK.That explains it.
Thanks alot Tom! You always give good answers.
Best regards!
Emil
This page was generated in 0.365 seconds.
