Offline Tom Jessop
#1 Posted : 30 August 2014 08:41:36(UTC)
Tom Jessop
For those of us who run E Locks .
From what I can see The catenary has a slope in its construction on either side of the gap , when the train runs thru the panto slowly raises to a point it can no longer & then disengages from the contact wire , runs thru the gap & then the reverse occurs . At the same time there is a control system which opens the master circuit breaker to stop any arcing between the panto & the wire .
Cheers Tom in Oz.
thanks 4 users liked this useful post by Tom Jessop
#2 Posted : 30 August 2014 08:53:59(UTC)
The description under the video reads: "The electric locomotives shut off power and lower the pantographs away from the wire as they pass through it. The process is automated."
Offline NZMarklinist
#3 Posted : 30 August 2014 09:22:39(UTC)
NZMarklinist
The Video Description
"Published on Aug 29, 2014
Located just to the east of Coppabella is a gap in the overhead where they bring the over sized Tonka toys in to the mine. The electric locomotives shut off power and lower the pantographs away from the wire as they pass through it. The process is automated."
Glen
Auckland NZ
Offline Tom Jessop
#4 Posted : 30 August 2014 12:20:52(UTC)
Tom Jessop
From what I saw the pantos stay in the normal operating position , raising & lowering while powering would cause arc over while moving . I worked on elocs on coal ttrains for15 years doing things like that was asking for trouble . Do not believewhat is always printed espec on youtube .
Cheers Tom in Oz.
#5 Posted : 30 August 2014 14:12:15(UTC)
At 0:16-0:19 I get the impression the panto goes down a bit. Could be an optical illusion as the angle of view changes.
With respect to arcing it makes no difference whether the wire goes up or the panto goes down. No arcing, so loco draws no power while disconnecting (as written in the YT description).
Yep.
Offline Tom Jessop
#6 Posted : 30 August 2014 23:04:53(UTC)
Tom Jessop
Beg to differ , from my railway work experience , there is NO panto which can be partially lowered , it is fully up or fully down , there is a height stop along with a pressure measurement fitted to pantos to stop over travel & excessive tension being applied to the catenary .
Cheers Tom in Oz, where the sun has eventually been seen after almost a fortnight of heavy rain.
Offline Robert Davies
#7 Posted : 31 August 2014 02:22:19(UTC)
Robert Davies
While I agree with what you say about partial lowering, when you say 'fully up', I presume you mean 'as far up as the contact wire will let it go'.
British locos and EMU's with pantographs are all fitted with an over-height switch which automatically drops the pantograph if it gets up to its maximum height. Operating at maximum height is never required by the overhead system design so the logic is that if it has got to maximum height, it must have come off the wire!
Robert
Era III - IV
Hardware versions 3.6 / 4.33
Software version 4.2.1 (0)
thanks 1 user liked this useful post by Robert Davies
Offline witzlerh
#8 Posted : 31 August 2014 22:32:46(UTC)
witzlerh
It appears that the wire height climbs up higher that the pantograph can go. There may be a process where the driver may set the throttle into neutral so that there is no current draw.
There could also be no current in the wires in the section where the wires climb so there would be no arcing. The wires are isolated from the main power and grounded or shielded to prevent arcing.
If I were designing this, I would have the wires climb out of the way. Someone or somehow, the pantograph may be forgotten to be lowered and cause damage and delay.
The pantograph high limit alarm would have to be disabled or removed.
There also has to be a means to maintain power to the electronics during the gap; either through large capacitor, batteries or generator. Failing that, I would expect the brakes would automatically engage when there is total loss.
This is neat to see! Thanks!
Harald
CS2 DB & Canadian Era 3-6
This page was generated in 0.534 seconds.
